Spare Parts 64-66 4x4 Build
Ok, I am going to need some advice in the next few weeks.
I am starting a project from my spare parts collection. I have a 64-66 4x4 frame & a 2005 6.0 w/ 5 speed from a 2wd as a base. The current plan is to set the 6.0 & nv 4500 trans in the 64 frame & use the divorced case. I was planning to ditch the stock front end update it with a Dana 44 or perhaps a Dana 60. I have several parts trucks, so I am really not to keen on buying anything big vs. using what I have. Here is my last project. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Spare Parts 64-66 4x4 Build
Sounds like you have a good build planned. That looks like a fairly decent truck to start with.
The one above was pretty good to start with, the cab floors were rusted due to carpet issues. It is a dedicated puller. I have no plans to do much else to it other than smooth up the fenders some day.
Post Whore
![]() Join Date: Mar 2013
Looks like it'll be a cool ride! I'm in.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
this build will be interesting.
1961 chevy K10 my build is------------61K10 build |
Here is what I am starting with. I am not sure exactly what year this frame is it had a 64-66 Chevy cab & bed on it.
I need to figure out what engine cross member to use with it. I am going to try a 4x4 engine cradle from a newer Chevrolet 4x4 78 - or newer than that. I plan to use the ls conversion mounts to use the older style clamshell mounts. |
60-66 Nut
Don't know if it matters but that frame is a '60-'62.
Well here is my transplant. I actually have the cab off at this point going to pull the engine & trans tomorrow. Kinda curious at this point to get it hovering above the frame to see how short the first drive shaft will be.
Well the 6.0 is now hovering above the 60-62 frame. At first I thought I might be able to mock up the original 2005 mounts to the older frame, but it seems like it would be more trouble than it would be worth.
I am going to order up some conversion plates for the older clam shell mounts. & next step is to measure a 73-87 frame for a possible donor cross member. The trans mount is going to be simple. I had the stock 2005 Truck exhaust manifolds on, but at this point they look they wont fit at all. I ditched the ac for now & I am going to take off the power steering pump for the engine mock up. |
