09-25-2014, 03:13 PM | #1 |
What is a set of rally wheels worth?
How much do rally wheels usually go for? I have a set of 5 with trim rings and not sure what they're worth..
09-25-2014, 03:22 PM | #2 |
Re: What is a set of rally wheels worth?
I'VE SEEN THEM ON A REGULAR BASIS FOR FROM 10 A WHEEL UP TO 125 PER WHEEL it depends on condition and how much you want
09-26-2014, 05:38 AM | #3 |
70+ ( Old Skool Club )
Are you talking just the rally rim alone or are you including the centre cap and trim ring with them. Are the rims the 15 x 8's with the bigger trim rings or the 6.5 inch van rallys with the smaller trim rings. Are the centre caps ( if you have them ) the original metal ones or are they plastic.? Okay to answe your question, this wek I sold a set (4) of the 15x 8's with centre caps and the bigger trim rings for 175.00 I was asking 200.00 for them and dropped because the young fellow ( who had just bought a 72 C10 and wanted the rallys for it ) worked me a bit so I let him have them. Depending on condition around here asking prices are 150.00/250.00
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-26-2014, 07:03 AM | #4 |
I bought a set of 4 for $20 a wheel. They where 15x8's 6 bolt pattern.
09-26-2014, 12:20 PM | #5 |
Thanks for the feedback. Here are some pics, I'll check on the width.
09-26-2014, 03:24 PM | #6 |
Okay, you have 6 hole 15 x 8's and the good wider trim rings. Unless you are going to those rims on a mudder truck they need some work and you would have to find caps as well. I wouldn't pay more than 50.00 for all four.
