09-29-2014, 10:31 PM | #1 |
Easy Does It
Z bar mount question
I currently have 68' with a inline 6 engine and was thinking about a V8 swap, are the z bars and mounts different, and if so where can I find them?? thanks
09-30-2014, 03:59 AM | #2 |
Re: Z bar mount question
The z bar is the same the engine bracket is not.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
09-30-2014, 07:04 AM | #3 |
I got everything I needed from the Parts Board. I had to do a little custom fabricating as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=601024 |
09-30-2014, 07:29 AM | #4 |
V8 and L6 Zbars are not the same.
10-01-2014, 07:53 PM | #5 |
Just did this one last winter on the green 68 , left the v8 in the 6cyl spot , used the 6 cyl z bar , screwed a clutch ball in the block on my 283 , and never looked at it again. very easy.
10-01-2014, 09:26 PM | #6 |
Just swapped out my 250 for a 350. Original z-bar works great. Not sure if there's a difference, but the 6 cyl z-bar does work
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
