10-03-2014, 11:48 AM | #1 |
BlahBlahBlah
2007 Trailblazer tune up?
Well I hate working on any of the new vehicles, but its time to tune the wife's Trailblazer.
So you guys with experience tell me what I need to pick up to give it a tune up. Its the 6 cyl version. Plugs, what else? O2 sensor? There is a check engine light on. I could probably take it over to Napa and have them tell me what the light is. Did I mention I hate working on new stuff?
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
10-03-2014, 03:46 PM | #2 |
Re: 2007 Trailblazer tune up?
Tune ups on those are pretty easy. Just spark plugs and an air filter. I would highly recommend ac delco double platinum or iridium plugs.
10-03-2014, 09:43 PM | #3 |
BlahBlahBlah
Well that's nice to hear. Ill probably change the oil too long as Im crawling around =)
10-03-2014, 10:08 PM | #4 |
Yep, plugs, air filter and fuel filter. These chew up coils. Let me know what your code turns out to be.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
10-04-2014, 01:14 AM | #5 | |
yup, give me old... |
10-04-2014, 09:12 AM | #6 |
Plugs, filters, then take it to your local dyno-tuner to reprogram the computer to really make it feel like you did an engine swap. If you are on a ‘stock’ computer tune you are missing so much..
tubbed 1984 gmc jmmy http://67-72chevytrucks.com/vboard/s...d.php?t=639738 Alice Hombre http://67-72chevytrucks.com/vboard/s...d.php?t=808454 |
10-04-2014, 11:19 AM | #7 | |
BlahBlahBlah
It has 130K on it.
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 Last edited by CG; 10-04-2014 at 11:26 AM. |
10-04-2014, 12:20 PM | #8 |
did you run a few cans of seafoam thru it lately?great for cleaning injecxtors and sometimes it solves the engine lights too
10-04-2014, 01:48 PM | #9 |
There is NO fuel filter to replace. Pull that of the list.
Trueman |
10-04-2014, 02:40 PM | #10 |
BlahBlahBlah
Ive heard of seafoam but Ive never used it. Ill look it up online and check it out.
10-04-2014, 04:12 PM | #11 |
yhe fuel filter is in the tank,leave it alone
10-04-2014, 05:46 PM | #12 |
BlahBlahBlah
Changed the oil, oil filter, air filter. Washed and vacuumed. Filled up the tank and added a can of the Seafoam. Had the code checked and it was something about the catalytic converter, reset the code. Put in 5 new spark plugs. Cant get the rear most one out, its way under the stupid cowl. Ill figure it out later =) Put on new wiper blades. I think she is ready for winter.
10-04-2014, 07:50 PM | #13 |
10-05-2014, 10:40 PM | #14 |
blood type; Retumbo
Get that rear plug changed. I use a shallow socket with a 3" extension all in 1/4" variety then after it's unthreaded use a piece of 3/8" fuel hose to pull it out
P0420- cat conv efficiency low, bank 1. It may need scanning to see if converter is weak or if upstream O2 is slow mimicking the downstream sensor. It wouldn't be the first time I've seen a gm converter fail. I don't have proof but I suspect it's small amounts of dexcool leaking into cylinders and killing converters
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
10-06-2014, 01:50 AM | #15 | |
not sure in your area on cost, can be $50-250. last one i had done cost me a 5th of jack. should look into it.
10-06-2014, 11:46 AM | #16 | |
BlahBlahBlah
