Old 10-10-2014, 12:47 PM   #1
Paul Y
Anyone got a part number for Energy Suspension bushes?
Spent a while searching but come up with nothing.
What part number are you using?
Thanks in advance.
P
Paul Y is offline   Reply With Quote
Old 10-10-2014, 04:33 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Anyone got a part number for Energy Suspension bushes?
sway bar bushing?. control arm bushing?. leaf spring bushing? trialing arm bushing?.
you might give us a little more info to go on to help ya out...
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-10-2014, 04:50 PM   #3
Figuarus
Figuarus's Avatar
I'm at work and have a catalog in hand. what are you looking for?
I'm an idiot.
Those arms use a metal sleeve. There is no rubber in them.
The only bushings they offer for arms are the rear trailing arms
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 10-10-2014, 04:51 PM   #4
Paul Y
Currently laughing very hard as I am pretty much a ringer for Dr Evil....
So.... I am looking for upper and lower control arm bushes. Now it might be that they are not Energy Suspension, what would you recommend?
And yes I deserved that!
p.
Old 10-10-2014, 04:54 PM   #5
Figuarus
Figuarus's Avatar
p.
Well, We still need to know what we're working on here. what truck?
2013 Malibu LTZ
Old 10-10-2014, 04:56 PM   #6
Paul Y
ok 1966 c10 -Fleetside shortbed.
Thanks for your help.
P. D
Old 10-10-2014, 05:01 PM   #7
Figuarus
Figuarus's Avatar
I forget that they don't use rubber or poly bushings on those arms.
See here
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=88
I can get you part numbers for the rear trailing arms.
2013 Malibu LTZ
Old 10-10-2014, 05:52 PM   #8
Paul Y
Thanks, I know that a number of member have used poly bushes but what do they use?
This is for the upper and lower control arms
P.
Old 10-10-2014, 06:01 PM   #9
Figuarus
Figuarus's Avatar
dunno. Unless they have the 67 or newer control arms with the rubber bushings.
If your truck is a factory 66 without modifications, then you don't have anything available in a poly bushing.
2013 Malibu LTZ
Old 10-11-2014, 01:17 AM   #10
Captainfab
60-66 Nut
All C10, 20 and 30 trucks from '63-'72 use steel bushings on the control arm shafts. The '73-'87 front suspensions use rubber control arm shaft bushings that can be changed for urethane bushings if desired. If you have seen someone install urethane control arm bushings on their '63-'66 truck, they have changed to the '73-'87 control arms.
