Old 10-12-2014, 09:56 PM   #1
Rollinsqrbdy
Rollinsqrbdy's Avatar
12" superlift problems...
I recently put a 12" lift on my 79 Chevy. Everything went together real good. But I cant make the front drive line work now. I was told to shim the front leaf pack . Im trying to get it ready for some local mud boggs. Anyone have some ideas? Thanks in advance for any help.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 10-13-2014, 09:22 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 12" superlift problems...
I'm assuming the angle to steep? Normally, when you lift your truck that high you have to go with a high angle drive line.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 10-13-2014, 12:32 PM   #3
dieseldawg142
dieseldawg142's Avatar
you could shim it, but you will most likely screw up your caster.
the best way would be to cut & turn your knuckles (expensive $).
i'm running 8" lift in my crew, to make the front work without binding i dropped my t-case, ground out the stops on the cardon at the t-case & put a longer, hi-angle slip on the diff end of the d.shaft. been running it for yrs with no troubles
dieseldawg142 is offline   Reply With Quote
Old 10-14-2014, 12:11 AM   #4
86454k30
86454k30's Avatar
1 of 2 options for that much lift, a driveline from Jessie at high angle driveline I think in $800.00 range or a divorced transfercase. I don't think there is anyway to make a stock driveline work no matter how much you shim the front axle, dropping the transfercase only makes the front angle worse because it tips the transfercase up.
86454k30 is offline   Reply With Quote
Old 10-14-2014, 12:23 AM   #5
IIGW
you need to do the ole' cut and twist..
cut the knuckles loose, twist the axle to point the pinion where you need it, and reweld the knuckles... you'll keep the stock caster.
IIGW is offline   Reply With Quote
Old 10-14-2014, 11:32 AM   #6
dieseldawg142
another option would be to throw a doubler in there & cut your angles down.
it's not a 12" lift, (8"), but i dont think your going to get more stock than this.
Size:  57.0 KBName:  019.jpg
dropping the t-case minutely raises the front, but the overall drop more than out weighs that. stock driveshaft with ground stops on the cardon & a spicer hi-angle, longer slip (very nice piece worth the money) on a stock low pinion D60.
Old 10-15-2014, 08:24 PM   #7
Mike C
Mike C's Avatar
6" lift kits say "may require driveline modifications. 8" and up definitely require longer driveshafts on both ends.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-15-2014, 11:20 PM   #8
dieseldawg142
quite often that is the case, especially with a 12 incher, but not always necessary with smaller lifts.
call me lucky or whatever, but i'm running the stock d.shafts in my 8" lifted k30 crew.
the front shaft i did buy a longer slip yoke, but the rest of it is GM 1 ton issue.
the rear shaft all i did was drop the carrier bearing down a few inches with a piece of sq tubing, the aft part pulled off the slip about 3/4", have never managed to yank the other 4" off the slip....
Size:  40.1 KBName:  056.jpg
Old 10-21-2014, 06:25 PM   #9
TRUCKGUY
TRUCKGUY's Avatar
What about using a dropped tcase (not sure of the propper term) but like they use for the bigger trucks the drops both front and rear shafts down
Dan.
55 F100 panel truck project
64 350/th400/10bolt short fleet
66 F100 302/C6/9" short fleet
67 IH 4x2 304/t984speed D44 373 locker lwb box
67 IH 4x4 304/t98 4speed/d44/d60 4.10'slwb box
67 IH Travelall 4x4 304/t98 4speed/12bolt/10bolt
81 2wd short fleet current build!
83 350/700r4 short fleet
88 k5 12" lift 3/4 ton swap mud toy
96 Dodge 3500 CUMMINS/5speed/4x2
97 Pontiac Trans Am WS6/LT1 383/6speed/T-tops
TRUCKGUY is offline   Reply With Quote
