Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-27-2014, 03:27 PM   #1
65chevysub
65chevysub's Avatar
Fuel guage going nuts
Just got my 65 Sub running again, and when I started it, and while driving, the fuel guage needle is going nuts, fluttering back and forth. Could this be a ground issue? I had the tank out awhile back, and thought I got the ground wire tight. Any ideas? Thanks
65chevysub is offline   Reply With Quote
Old 10-27-2014, 06:24 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Fuel guage going nuts
Remember, these tanks are not baffled so movement of the gas inside will cause it to fluctuate back and forth, while driving.
If you are sitting still and it's doing it, it's likely a bad ground or sender wire connection.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 10-28-2014, 08:20 AM   #3
65chevysub
65chevysub's Avatar
Thanks. It does do it sitting still as well as driving. I'll check the ground wire and sender unit wire
Old 10-28-2014, 10:58 AM   #4
chevy_mike
chevy_mike's Avatar
I have found over the years that most electrical problems are 90% bad grounds and 10% bad, missing or incorrect wiring.
Old 10-28-2014, 10:07 PM   #5
65chevysub
65chevysub's Avatar
I'm thinking bad ground. It didn't do all the jumping around a few months ago before I dropped the tank.. Now all I have to do is correct the lights in my cluster and I'm good. Thanks for your help
