Old 10-29-2014, 10:15 AM   #1
taylorbg
Pitman arm
I am replacing all the steering parts on my front end. Do I need a drop pitman arm? I would rather not spend the $115 if I do not have to. Below is a picture of my truck and a picture of the existing pitman arm. I have ordered all Moog lower and upper ball joints, upper, lower, inner and outer tie rods ends, and adjustment sleeve.
I am also going to get a Leaf spring polyurethane bushing set.
Is there anything else I should replace while I am in there?
1972 4x4 Suburban
http://www.summitracing.com/parts/sj...l/k10-suburban
taylorbg is offline   Reply With Quote
Old 10-29-2014, 04:33 PM   #2
k5xjfiles
Junior Member
k5xjfiles's Avatar
Re: Pitman arm
If you feel the angle is bad....which it does not look bad to me.....no sense replacing it.
72 K5/10/20 Hybrid 350, 465/205 44/14 bolt 35s, Detroit locker
89 XJ Pioneer, 4.5" 32s.
98 ZJ DD.
Parting..87-01 Cherokees
I bore throttle bodies-PM me for details!
k5xjfiles is offline   Reply With Quote
Old 10-29-2014, 08:14 PM   #3
franken
Re: Pitman arm
If you don't have a big lift no. It that 4-6"?
Pics come out better if the sun's behind you.
franken is offline   Reply With Quote
Old 11-05-2014, 08:05 PM   #4
Mike C
Mike C's Avatar
Re: Pitman arm
I replaced mine on the Jimmy because it was just worn out after 300k plus miles. If you can tighten the pinch bolt and it doesn't move up and down like mine did when turning the wheel, it should be good to go.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-15-2014, 12:37 PM   #5
backwoodsK20
backwoodsK20's Avatar
Re: Pitman arm
Is one required for a 4-6" lift? even to be on the safe side? I have the same question about my build, and I won't mind dropping ~$130 if it's the better way to go.
1968 Chevrolet K20 4x4. 292 c.i., SM420 4 speed, Rockwell t-case, & '78 14-bolt FF diffs w/ Detroit Lockers. Built to hunt, fish and trail ride for days.
backwoodsK20 is offline   Reply With Quote
Old 11-15-2014, 06:01 PM   #6
Mr. 250r
Mr. 250r's Avatar
Re: Pitman arm
Its usually just required when the angle is no longer "level" per se i am not sure where its going to come in at exactly in terms of lift size but your pitman arm angle isn't really bad as stated you would probably need the smallest possible drop otherwise its going to push it past level. From the looks i think a 1-2in drop would probably put it at level not sure how much that would help though.
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 11-16-2014, 09:32 AM   #7
Bigdav160
Bigdav160's Avatar
Re: Pitman arm
I'd buy one. I think I only paid $60 from Summit for a raised steering arm. Even with a 2" lift my Suburban had pretty good amount of bump steer.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-19-2014, 05:12 PM   #8
backwoodsK20
Re: Pitman arm
Wait, doesn't the raised steering arm accomplish the same thing? Reason I ask is most companies offer this as an option with their lift kits for ~$95 and i'm wondering if I could just do that.
Old 11-19-2014, 05:38 PM   #9
bmchevy1979
bmchevy1979's Avatar
Re: Pitman arm
On my 74 I know different body style but same setup I used the drop pitman arm for 2"-3", the raised steering arm 4"-6", and both for 6"-8" and beyond that I would recommend crossover steering
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 11-19-2014, 05:41 PM   #10
bmchevy1979
Re: Pitman arm
The raised arm is has more of a change than the drop pitman arm it moves the tierod from almost touching the axle tube to it being 3"-4" from the tube the arm only gains about an 1 1/2"-2"
<Brandon>
Old 11-22-2014, 09:13 PM   #11
obijuan
Re: Pitman arm
You do not need anything.
obijuan is offline   Reply With Quote
Old 11-25-2014, 01:23 PM   #12
72shorbox
Re: Pitman arm
I would recommend replacing the u-joints in the front axle shafts while you have the front torn down replacing the ball joints.
72shorbox is offline   Reply With Quote
