Blue 67
![]() Join Date: Apr 2004
Air compressor: which of the two?!
Hi:
These compressors have a very close final cost. They are the same brand (puma) and same capacity (60 gallon). which one do you chose: First: 6.5 HP, 135 max PSI, 19.5 CFM at 90 PSI, 28 amp Second: 4.5 HP, 150 max PSI, 18 CFM at 90 PSI, 17 amp Thanks for the input.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
Re: Air compressor: which of the two?!
depend on what your doing, id go less amp and focus on more storage space. IVe painted my cars several times, sand blasted all day, all on a $100 3hp 6gal unit but I have about 300gal of extra storage with used 100gal 300psi propane tanks. Storage volume makes up for less HP, more HP makes up for less storage volume.
I am a Referee of life.
More storage space is good. More storage space will also cause the compressor to run longer and wear out the pump etc. quicker. Since tanks are the same size either will have the pump for the size. If it's for your shop at home, go lower amps. Either will run just about any air tool up to really big commercial stuff. The higher amp one will use more power but might be better if you're doing a LOT of blasting.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
blood type; Retumbo
the second one sounds like it will be running on the ragged edge of self destruction
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#5 | |
Blue 67
Thanks for all the comments.
IVe gotten 10 years of use from my $100 one, does takes about 30mins to fill the tanks from empty, and it does run if in use but only bothers part is the noise if close. [ most of the noise comes from the intake ]
#7 | |
![]() ![]() Join Date: Jul 2002
The larger one probably is oil/spalsh luibe and you can change the oil and get longer life. Since I paint, I would go with the high CFM one myself, if everything else is equal. If the smaller one is self lubricant, then go with the bigger one.
Parts and more parts
What is your power capability? I just replaced my home compressor and I had to upgrade some of my wiring to get the power to the compressor, without any voltage drop. That is where you will run into issues.
Frank |
Blue 67
I have a 220 with dedicated 30 amp breaker for the compressor. I just did the wiring. It is a new hobby shop/garage. I plan to do some body work and painting. It is just for personal use, nothing commercial ad that is why I have hard time to decide about the higher CFM versus the final PSI. I have even thinking about a 80 gallon single stage pump instead of the 60 gallon. I still have a hard time deciding!
Your 28 amp compressor is close to what you have for a breaker. What size wiring did you run and how far to the compressor from the breaker box?
Attached is a picture of what I put in my garage just a few weeks ago. To be safe, I ran 8 gauge wiring, since I was around 50 feet from the box, by the time I went around the corner of the garage. I got my compressor for less than the price in this add. http://www.northerntool.com/shop/too...5343_200455343
Frank |
