Old 11-11-2014, 02:52 AM   #1
CaliforniaDaddy
CaliforniaDaddy's Avatar
Will these V8 swap brackets work?
1950 chevy 97 S10 chassis with a SBC350 engine. I was wondering if anyone has used these for moving the motor back?
Trans-Dapt 4691 V8 motor mount swap plates
http://www.ebay.com/itm/171524505572...%3AMEBIDX%3AIT
“I would rather live my life as if there is a GOD and die to find out there isn't, than live my life as if there isn't and die to find out there is.”
CaliforniaDaddy is offline   Reply With Quote
Old 11-11-2014, 01:39 PM   #2
918733
Re: Will these V8 swap brackets work?
I got some that had 3 mounting positions (sounds dirty) that I will use with the mounts that came with my E-Z chassis kit so between the 2 it should work
918733 is offline   Reply With Quote
Old 11-11-2014, 01:50 PM   #3
1-ton of fun
polishing a turd
1-ton of fun's Avatar
thanks for the link! i just ordered those to see if they will give me the 2" setback i need for my motor.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 11-11-2014, 02:13 PM   #4
CaliforniaDaddy
looks like they might be able to give you more than 2" of setback.
I'm hoping I can keep the solid 4.3l mounting brackets in the stock location and use brand new 4.3L rubber mounts bolted to the bracket then bolt to block!
Old 11-11-2014, 06:39 PM   #5
918733
This is a pic of the one's I got and they don't seem like they will move the engine back enough with the stock mounts
Old 11-11-2014, 08:04 PM   #6
CaliforniaDaddy
I wonder if LS block is different? Im using a mid 70's Gen I block
Old 11-12-2014, 12:49 AM   #7
918733
Sorry didn't catch the sbc part I was looking at the pic of the mounts and they looked like the ls mounts and my mind just ran with it
Old 11-12-2014, 01:59 AM   #8
CaliforniaDaddy
oh lol no problem
