Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 11-15-2014, 09:54 AM   #1
parrisc19844x4_468
parrisc19844x4_468's Avatar
bucket seat brackets and inner towers.
These brackets I was told came out of a burb, but the will work in a truck as well. With these you can adjust both seats. I want $70 + ride.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 11-15-2014, 11:43 AM   #2
Sabaka454
Sabaka454's Avatar
Re: bucket seat brackets and inner towers.
Sent you a PM
Sabaka454 is offline   Reply With Quote
Old 11-17-2014, 04:49 PM   #3
parrisc19844x4_468
ttt
Old 11-19-2014, 12:07 PM   #4
parrisc19844x4_468
ttt
Old 11-20-2014, 03:27 AM   #5
qksilver
don't mean to show my ignorance but I will. I have a set of K-5 buckets and want to put them in my 87 cab, will these do that will out any rigging or fabrication?
I see 2 cut out parts and figure those are for the inside brackets, should there be 4 of those?
Pm me I tend to forget
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 11-20-2014, 03:59 AM   #6
gmachinz
The floor area behind the seat are similar for K5's and suburbans but the pickups are different as they curve up at the rears of the brackets. I used Suburban bucket seats in my 86 shortbox truck but to make them work, I had to ditch the suburban seat tracks and instead I used 2 sets of pickup bench seat tracks. The mods required for a stock look weren't difficult-I shortened both seat forward/backward adjusters by 3" and redrilled holes in the seat framing to accept the pickup track hole alignments. It wasn't a big deal since I wanted to keep it appearing factory. And it gave me an opportunity to clean up/grease all the seat track slides, tweak the seat adjustment cable, etc. You could caveman it by putting the suburban seattracks in a HD vise and basically bend the rears of the brackets from facing down slightly to up slightly-this way it should fit the pickup floor alignment-Ive seen it done that way too....just he careful where you bend up with it or your rear mounting holes will be off.
And for the rear inner mounts I drilled holes through the floor and then welded 10mmx1.50 nuts from underneath to keep it looking factory-then I wirebrushed the welds-primed/painted and then undercoated the area all from underneath.
gmachinz is offline   Reply With Quote
Old 11-20-2014, 10:10 AM   #7
parrisc19844x4_468
Thanks,
Steve
Hi Steve,
No you only need 2 inside brackets, if you look at the floor of you 87 (i assume this is a truck and not a K5) you will see why.
What I did for the ones I used, I used my original back seat bracket as a template and heated them my map gas and bent them , took about 5 mins.
I bent them right at the same spot where they are already bent.
Ok Funny story go to youtube and search for install bucket seats in a 73-87 truck. This guy spends hours replacing the part the fastens to the floor, when all he had to do was to bend it.
Old 11-20-2014, 10:38 AM   #8
gmachinz
Keep in mind though that seat brackets are formed pieces and heating them changes the tensile strength of the material. It will work but be careful with the amount of heat ifbusing that method.
Old 11-20-2014, 12:30 PM   #9
qksilver
thanks guys, then I all ready have the parts I need. Cool.
Again thanks,
Steve
Old 12-31-2014, 11:11 AM   #10
parrisc19844x4_468
ttt
Old 03-01-2015, 12:53 PM   #11
parrisc19844x4_468
bump
Old 04-11-2015, 10:39 AM   #12
Corts60
Just here to tinker
Corts60's Avatar
If you still have these, can you give me an estimate to 97217?
Thanks,
Cort
Old 04-13-2015, 06:36 AM   #13
levi426
These are xactly what I'm looking for.
levi426 is offline   Reply With Quote
Old 04-13-2015, 06:37 AM   #14
levi426
Pm sent
Old 04-17-2015, 08:07 PM   #15
402GMC
Are these still available?
402GMC is offline   Reply With Quote
Old 04-18-2015, 08:59 PM   #16
parrisc19844x4_468
yes
Old 04-19-2015, 11:00 AM   #17
402GMC
I'll take them! Send me your paypal info and ill send the money. Thanks, scott
Old 04-23-2015, 04:38 PM   #18
parrisc19844x4_468
Sold
brackets, buckets, towers
