11-17-2014, 08:03 PM | #1 |
Needs a Big Block
Hiway speed vibration
Hey guys , I'm fairly new to the 4wd business. In these trucks,
I recent bought a 72 K10 It cruises down the highway at great in 2wd hubs unlocked But I went out today with it in 2wd and the hubs locked and it's got an ugly vibration 60-70 mph. , The hubs lock and unlock smoothly, and after a good drive the hubs aren't hot , Where do I start looking ??
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
11-17-2014, 08:33 PM | #2 |
Re: Hiway speed vibration
Check to see if the hub/bearing assembly is assembled correctly. I have seen clip where washers should have been and vice versa. A
11-17-2014, 08:55 PM | #3 |
20' Daredevil (Ret)
With the hubs locked, the front driveshaft is turning even in 2WD. Might have bad u-joint / double cardan joint in the front DS, or bad u-joints(s) at the outer ends of the front axle.
11-17-2014, 09:24 PM | #4 |
Needs a Big Block
I had a moment there haha,
Yes I'm betting it's that drive shaft, I'll unlock the hubs and throw it in 4wd and try it again. That should narrow it down
