Old 11-24-2014, 04:02 PM   #1
Cuate
C10 5.3 Ls swap with AC compressor
I installed dirty dingo adjustable motor mount plates on my 5.3 engine and had to remove the AC bracket and compressor. Does anyone know a way to still use the 5.3 stock AC compressor? I didn't read the note on dirty dingo pg where it states that stock AC compressor can not be used. This engine is from a 2001 Tahoe and originally has AC compressor on bottom passenger side. Adjustable plates where pricy and I really was not planning on spending money on another AC compressor or brackets. Any ideas or solution will be appreciated.
Cuate is offline   Reply With Quote
Old 11-24-2014, 04:09 PM   #2
bterry97gt
Re: C10 5.3 Ls swap with AC compressor
I am not sure how the dirty dingo mounts are made, but to get the adjustable plates I got off of ebay to work I had to trim the AC bracket just a bit. Hope this helps some.
bterry97gt is offline   Reply With Quote
Old 11-24-2014, 05:40 PM   #3
rmv23887
I have been down that road, stock compressor not compatible with 72 stock AC or any system like Vintage Air etc. Just have to get a mount that moves the compressor up and use sandeen unit everyone uses....
I found there is a reason no ones doing it...
RandyV
rmv23887 is offline   Reply With Quote
Old 11-26-2014, 09:27 AM   #4
Kid
Kid's Avatar
RandyV
I keep seeing folks say that factory comp. won't work, but mine has been working fine for 7 years now. (2004 pu comp with Vintage air) can you explain what the issues are? Maybe I'm just lucky?
Kid is offline   Reply With Quote
Old 11-26-2014, 10:54 AM   #5
bterry97gt
I don't have any experience with these, but I have seen multiple people run them without issue. I plan to use the factory ac comp, so I'm interested to hear as well..
Old 11-26-2014, 12:42 PM   #6
wpotter
wpotter's Avatar
If you stock compressor is a fixed displacement compressor then it will work with the factory and aftermarket systems. If you have a variable displacement compressor then it is not recommended for use with original or aftermarket systems. Not sure which trucks have fixed or variable but I think all car LS engines have the variable. Hope this helps.
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
Old 11-26-2014, 04:56 PM   #7
anviltester
cpp makes a motor mount kit for the low compressor mount. try those.
anviltester is offline   Reply With Quote
Old 11-26-2014, 10:09 PM   #8
ss454conv
Wpotter is on the right track. Some truck compressors are fixed and they should work. You will have to verify which ones are or are not. The other good news is that if you have a variable displacement compressor, they can in some cases be easily converted to fixed.I have done this on my 70 Chevelle which I installed a 2004 GTO motor/trans in. I have only had it charged for the end of the summer, but it was blowing ice cold till I stopped driving the car in the fall. No fluctuating temps caused by compressor cycling. Do a Google search and you should find the article that shows how to do it. Good luck.
AJW
ss454conv is offline   Reply With Quote
Old 11-26-2014, 10:16 PM   #9
Cuate
Just wanted to post picture of dirty dingo adjustable motor mount plates. As you can see on picture why it doesn't work. Mount can still slide 2 or 3 inches forward but AC compressor bracket won't let even after trimmed. As soon as I get a chance to install motor on truck I will figure out what route to take.http://67-72chevytrucks.com/vboard/a...1&d=1417055117. I'm having trouble uploading picture.
Old 11-28-2014, 10:04 AM   #10
Cuate
Old 11-28-2014, 01:14 PM   #11
70blackfish
this 5.3 is 2011 and the AC comp. fit.
used POL sliding mounts,
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 03-02-2015, 07:57 PM   #12
BIG SWOL
so can anyone suggest a dependable mount that will clear the compressor .............. just brought my 5.3 and need to purchase some motor mounts now
BIG SWOL is offline   Reply With Quote
Old 03-02-2015, 08:20 PM   #13
Andy4639
Old member
Andy4639's Avatar
Talking Re: C10 5.3 Ls swap with AC compressor
If you guy's will go to the Ls pages you will find all the answer's you need.
http://67-72chevytrucks.com/vboard/f...prune=-1&f=206
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-23-2015, 03:55 PM   #14
Gooker928
I used ECE motor mounts on my 63 fits just like 70blackfish mounts did.
Gooker928 is offline   Reply With Quote
Old 03-23-2015, 05:15 PM   #15
cooperhw
cooperhw's Avatar
Originally Posted by Cuate View Post
Don't feel like the lone ranger. on my 67 Chevelle LS-2 I did the exact same thing and had to order a new compressor and brackets that took it up high on the passenger side. Mine had less than 500 miles on it. Quik performance is the one I ordered if I remember right.
"I feel your pain".
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 03-25-2015, 12:59 PM   #16
mattcrp1
mattcrp1's Avatar
My compressor would not fit due to the switch hitting on the mount. Isn't there a factory compressor with out the switch on the back that clears?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 04-16-2015, 11:30 PM   #17
l92powered77
Dirty dingo sells the accesory brackets that move your ac and power steering high up for clearence...
l92powered77 is offline   Reply With Quote
Old 04-17-2015, 10:47 PM   #18
68c10airstream
68c10airstream's Avatar
Look at 98-02 f body factory mounts, possible 2010 camaro, trailblazer ss 5.3-6.0. These factory mounts sit low and rearward out of the way for factory air compressor. It would require a frame bracket to be made but once done your compressor would be down low and probably use the inner belt grooves on the balancer as the factory did, and would be in a cooler place and the engine compartment would be cleaner looking, just my opinion.
68c10airstream is offline   Reply With Quote
Old 06-27-2017, 11:27 AM   #19
Billyburban
I haven't hooked mine up yet but it fits no problem. 73 engine stands & engine mounts 73 & up Dirty Dingo sliders
Billyburban is offline   Reply With Quote
Old 06-27-2017, 11:56 AM   #20
Gooker928
Not the best photos but here's how mines looks from under the truck and from the engine bay...
Stock compressor....
Old 06-27-2017, 01:23 PM   #21
Billyburban
Can you take some pics up high then of you fittings did you adapt your factory ac line to fit a newer compressor? LS engine ?
Old 06-27-2017, 02:19 PM   #22
Gooker928
I'm using vintage air...
I had a place here's in Houston put the factory compressor fittings on the VA hoses...
5.3 6l80e
Old 06-27-2017, 02:27 PM   #23
Gooker928
Old 06-27-2017, 02:32 PM   #24
Gooker928
Old 06-27-2017, 02:33 PM   #25
Gooker928
