Old 11-29-2014, 09:10 PM   #1
ls1man
ls1man's Avatar
5.3 conversion????
I have 5.3 out of a 01 1500 silverado with stock ecm and modified wiring harness do i need to turn off vats before trying to start?
ls1man is offline   Reply With Quote
Old 11-29-2014, 10:12 PM   #2
chev3600
chev3600's Avatar
Re: 5.3 conversion????
Yes. It will not run with vats enabled.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 11-29-2014, 11:56 PM   #3
skymangs
skymangs's Avatar
Definitely need the vats removed. If you don't want it spitting codes, it should have the downstream O2's and emissions diabled. I use Brendan from LT1swaps.com for PCM work.
skymangs is offline   Reply With Quote
Old 11-30-2014, 01:14 AM   #4
yossarian19
You'll also have some cross member / framing work to make it fit, driveshaft, etc.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 11-30-2014, 10:06 AM   #5
ls1man
ls1man's Avatar
Anybody use a bypass module? They sell them on ebay for $16
Old 11-30-2014, 10:29 AM   #6
yossarian19
Sure, you could do that.
If you aren't planning to run all 4 oxygen sensors, an evap can & catalytic converters, though, you'll need an ECM flash to keep from spewing trouble codes.
If you're getting an ECM flash, just ask them to remove VATS at the same time.
"Over my head"
