Old 11-30-2014, 01:00 AM   #1
gpat@earthlink.net
Active Member
LQ 9 Install in 72 BLAZER
What is the most current and best motor mounts and cross frames to use on LQ 9 and 4 L 80 combo into 72 Blazer.Good Pics would be great. Thanks for the info.
gpat@earthlink.net is offline   Reply With Quote
Old 12-04-2014, 04:52 PM   #2
Gobuffalo
Gobuffalo's Avatar
Re: LQ 9 Install in 72 BLAZER
I used my all of my existing small block parts. I had to modify the lower part of the crossmember and make adapter plates. Less than $100.00 with powder coating.
Gobuffalo is offline   Reply With Quote
Old 12-04-2014, 04:54 PM   #3
Gobuffalo
Gobuffalo's Avatar
From the top.
Old 12-04-2014, 04:57 PM   #4
Gobuffalo
Gobuffalo's Avatar
Home made adapter plates. Engine mounted in the standard rear small block position.
Old 12-04-2014, 05:00 PM   #5
truckdude239
truckdude239's Avatar
Moved to the lsx section
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-04-2014, 10:30 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: LQ 9 Install in 72 BLAZER
I used my stock truck mounts with adapter plates with new pads.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-05-2014, 02:24 AM   #7
Nitis
Nitis's Avatar
I think when I do my K10 I'll be using dirty dingos crossmember. Pacific fab has one also. Requires s&w suspension lift but 2" lift big deal
In a 4x4 LSx crossmember must be modified
Nitis is offline   Reply With Quote
Old 12-05-2014, 10:05 AM   #8
Wasted Income
Boosted Member
Wasted Income's Avatar
I went the Dirty Dingo route on my K10.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-05-2014, 12:55 PM   #9
Nitis
Nitis's Avatar
Wasted how far along are you since these photos? I'm curious to see how the clearance is and how much suspension lift may or may not be needed
Old 12-05-2014, 03:17 PM   #10
Wasted Income
Boosted Member
You could say it's pretty far along. lol.
Sorry for the pic barrage but here are the only pics I could find that might hint at the clearance. It's got a 4" Skyjacker softride on it.
Turbo diesel
Old 12-05-2014, 03:20 PM   #11
Nitis
Nitis's Avatar
Looks awesome!
in your opinion would 2 or 2.5" be enough clearance. you look to have plenty
Old 12-05-2014, 04:16 PM   #12
Wasted Income
Boosted Member
Yea I think that 2 or 2.5" would probably be enough as long as it's not a rock bouncer or something. For a street truck...no problem.
Turbo diesel
