Blazer Value
Looking for opinions...do you guys think it would devalue my truck if I install this Hickey style roll bar in my Blazer. I had the roll bar fabricated and fitted in my 1969 K5 but I want to install it in my 1972 K5, should fit right? Main reason I want to install it, is it looks cool and it adds safety if I were to ever roll the Blazer. I don't like the idea of drilling holes in my Blazer either since it is original. So what are your opinions
1972 cheverolet K5 CST Blazer 350/auto/AC/PS/PB/Aux Batt From Medford, Oregon |
I'm trying....
![]() Join Date: Oct 2013
Re: Blazer Value
I can't imagine that it'd devalue that Blazer in the least, especially if it's a period style bar. I also think it's the smart thing to do, especially if you're going to drive it. That being said, I don't like the look of a bar with the top on or off and have struggled with the decision myself. I have decided to go no-bar, but wouldn't begrudge anyone who thought otherwise.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Blazer Value
Trying to make the same decision for the same reasons. Aesthetically I prefer the clean look of top off no roll bar but I also like to use my arms and legs, etc. A period correct roll bar would not deter me from buying a 4wd K5.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
SKINNY TIRES RULE!
Re: Blazer Value
I don't think it will devalue your rig. As for safety, it probably isn't a huge amount of protection, but a bit more than not having one. I'm with IronCanine and have made the decision to not add a roll bar but I wouldn't remove one if I bought a rig with a nice one installed.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Re: Blazer Value
I'm looking for a 72 blazer too buy and would perfer to find one with a period correct bar.. I like the looks and the added safety. I'm also looking for a stock blazer as well...
Re: Blazer Value
I had the same thoughts about the rollbar, Although I've never liked the looks of them, I thought I had to have it for safety reasons. Then noticed how many convertible cars do not have rollbars. Where I live the only 4 wheeling is on the beach, a nice salty place my blazer will never see.
Carpe manana
Re: Blazer Value
Example pics:
Re: Blazer Value
Without a rollbar you're likely to die or be fairly injured in a rollover. The top doesn't offer a ton of protection but helps. If you're topless then the windshield pillar is not strong enough to hold up 5000 lbs from crushing you. I like the look of a rollbar and I finally found one to Put in Mine again. It will not devalue your truck in any way as I see it as adding a safety feature and imho looks better than not having one. Just do it correct since yours looks to be in beautiful shape and you'll be fine.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
Re: Blazer Value
That pic above makes me wonder if they lived. The cop is staring at what could be a fatality.
![]() Join Date: Jan 2014
Re: Blazer Value
Can anybody post up more pics of these period correct rollbars? I cringe when I look at the one in my K5. I will definitely be adding some new type of rollbar soon.
![]() Join Date: Nov 2010
Re: Blazer Value
Ive got one of those old Hickey roll bars in my Blazer, often think of going from 4 point to 6 point, but as far as looks go, a Hickey 4 point in a topless first generation K5 is timeless, my 2 cents.
Re: Blazer Value
I had a six point on from the previous owner. I cut it out because they put it I. Lopsided. It really bothered me they didn't take the time to measure and put it in right. I just found a duel hoop 4 point to put back in. I think it's going to look much tougher with it than just a standard bar.
#13 | |
Re: Blazer Value
#14 |
Active Member
![]() Join Date: Jun 2013
Re: Blazer Value
WOW.....looks great! And so does the Blazer!
Love the Orange. What's the height difference between the front and rear lift?
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2012 Ram 3500 4WD Dually, 17 Dodge Challenger, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more. Wife: 06 GMC Duramax 3500 4WD Single Wheel, 2016 BMW X3. Next: Rust removal on my Blazer. Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup. ![]() Members Met: Aldtime, DeadheadNM |
#15 |
Re: Blazer Value
Looks like a six inch lift on both sides. But the slope of the driveway makes it a illusion of higher rear. Looks like to Me.
#16 |
Re: Blazer Value
I'm debating this myself. I like both looks. Curious, did you have build off of a drawing or is it complete custom for your truck? Where did you have if fabbed up?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#17 |
Re: Blazer Value
I had it fabricated off of some drawings I found on this web site however these drawings are only good to use as a reference they are not the most accurate. So when I had the roll bar fabricated we fitted it as we went along.I had it done by a local guy here in Houston.
#18 |
Re: Blazer Value
I made mine 2wd but am keeping the rollbar in as it provides a rear strapping point for my Jeep style bimini till I can find a full conv. top that I like. After that I think it will come out and be for sale. My truck is lowered and has front and rear sway bars so it's not going to roll over me thinks.
I think they look fabulous on 4wd Blazers though. Yours might be a bit nice for drilling holes in. I don't think I would even drive that nice of a truck. Doesn't look like you will be doing any real 4x4ing in that nice of a rig so you must be putting it in for aesthetic reasons? Of course you might be 4x4ing some day and wish you had one. I see your problem now. Fwiw-I was in a 50mph t-bone accident in mine and went spinning down the highway with 6"lift and 36" Super Swampers and no sway bars-hit a curb with both sidewalls front and rear and it just jumped the curb. Thought for sure I was gonna roll but it never even tipped.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 12-08-2014 at 07:47 AM. |
#19 | ||
Re: Blazer Value
Asolde, Your truck looks great! Be careful in when fabing up a roll bar directly from prints. The interior width of a single wall vs a double wall it quite a bit different. Make sure you compare actual top interior clearance to what you want to build. Good luck!! Make sure you post some finished pics!! ![]() Eric |
#20 |
Re: Blazer Value
Your 33x13.5 is what threw me off then. As wide as they are they looked more like my 35s and 5 inch lift. Looks like a good stance though.
