Old 12-02-2014, 11:16 AM   #1
dhtrack9
Unhappy Temp gauge high after rplc radiator
I have a gmc sierra 2000 w/5.3 engine, I just replaced my old radiator that had 199K miles, the old radiator was cracked and leaking so I replaced it. after I replaced it with a new one my temp gauge starting rising past the normal range after running the engine for 20 minutes or more. I felt the top radiator hose and it was hot, noticed when I turned on the heater only cool air was blowing (strange)......I did not change my thermostat yet and I did not replace my rad cap when I change the radiator....I'm stumped as to what could be causing this.....before I only had a leaking radiator and temp gauge was normal until I ran low on fluid.....Help please!
dhtrack9 is offline   Reply With Quote
Old 12-02-2014, 02:19 PM   #2
SeventyOne
Re: Temp gauge high after rplc radiator
Did you bleed the air out of the system?
SeventyOne is offline   Reply With Quote
Old 12-02-2014, 02:59 PM   #3
Daddy'O
Daddy'O's Avatar
X2 - sounds like it needs to burp.
Cheers - Wayne
Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966
'55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157
1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy"
1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55
Nothing sucks more than that moment during an argument when you realize you're wrong.
Daddy'O is offline   Reply With Quote
Old 12-02-2014, 04:21 PM   #4
dhtrack9
When you say bleed the air out of the system I'm not sure how to do this? I did not flush the coolant system completely, if that is what you are referring to.
I spoke to a Firestone service rep and they suggested I replace the thermostat since my old radiator was cracked and to flush my coolant system, not sure if that is a bad suggestion.
Old 12-12-2014, 04:18 PM   #5
flyingtim01
No need to make a mess with flushing & changing the thermostat if it was working properly before and you're not looking to complicate things. Not a bad idea to get a new radiator cap.
Fill overflow tank to full cold mark. Make sure radiator is full. Loosen radiator cap (old or new) and start engine. Turn heater all the way up, blower, on medium.
I'm guessing that once it gets up to operating temp and the t-stat opens, you'll see the level in the overflow tank & radiator drop. Keep them both full while the truck runs.
Once you get a steady reading near the 210 mark on your temp gauge, you can close up the radiator cap and top off the overflow tank if need be. You should also be getting good heat in the cab at this point.
If you still have no heat, and the temperature still climbs past the 210 mark, and you haven't had to add any coolant yet, then it's probably time to change the thermostat (because its stuck closed).
More than likely you're just air bound and the system needs to burp a few times and purge the air. You may even need to bleed it more than once to get the air out of the high spots once and for all. The dead giveaway for air in the system in a temp gauge that is constantly going up and down 20-30 degrees.
1971 Chevy K20 350/SM465/NP205
flyingtim01 is offline   Reply With Quote
radiator, temperature gauge
