Old 12-03-2014, 04:30 PM   #1
donthekawguy
donthekawguy's Avatar
1 ton questions
I'm hoping to start a mobile blasting business in the next couple of years and would like to have an older truck to put everything on. Are there any power disc brake conversions for the big trucks and I would like to have AC sometime in the future and power steering. I will be hauling a bit of weight and think a 1 ton should be up to the task. Also, would 5.3 swap be a good idea? Not so much for speed but for comfort in case I have to go out of town. It would really suck to have to drive a couple of hours with the stock 6 banger and who knows what gears.
Heres a couple I have been looking at,
http://spokane.craigslist.org/cto/4767330853.html
http://spokane.craigslist.org/cto/4762121992.html
http://spokane.craigslist.org/cto/4700364895.html
66 shorty
donthekawguy is offline   Reply With Quote
Old 12-03-2014, 05:07 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1 ton questions
I just finished a power disc swap for a 1947 1 Ton, also installed AC and power steering.
http://67-72chevytrucks.com/vboard/s...d.php?t=628174
we didn't end up using the bearing conversion and kept the stock wheel bearings
it also shows the power steering conversion we did using a 67 C10 hardware and made a new drag link. The engine is a 292 6 cylinder and a 14 bolt rear end
it does 65 with no problems, keep the original seat if you want comfort. 1 tons ride hard without the old seat in them
dwcsr is offline   Reply With Quote
Old 12-03-2014, 06:19 PM   #3
_Ogre
_Ogre's Avatar
Re: 1 ton questions
the 47 looks like a 1.5 ton from the size of the wheels and fender openings.
can anyone confirm this?
you'd definitely want new running gear as it's probably a 5.17 or higher rearend
unless you enjoy cruising at 45 mph
shop air compressor timer
Old 12-03-2014, 07:21 PM   #4
OrrieG
OrrieG's Avatar
Re: 1 ton questions
Here is a big bolt on a shortened late 80s 4wd dually frame. The bed is 8'. has a 454 and what ever auto trans/tranfer came with it. Had all the hard stuff done needed the interior and final body work. He sold it for 5K with out the Alcoa wheel conversion. I never drove it on the highway but he said it cruised easy at 70.
OrrieG is offline   Reply With Quote
Old 12-03-2014, 07:58 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1 ton questions
here is the 47 1 ton we just finished. Some can have dual rear wheels but i'm not sure about the big wheels
