12-06-2014, 12:41 AM | #1 |
'59 Gmc exhaust questions
I would like to go dual exhaust how much does dual normally run, I have a 270 with stock manifolds and hope to do dual
What is the best Muffler? I like the way Magnaflow sounds, I want something that sounds good
1971 GMC Sierra 1959 GMC 100 |
12-06-2014, 03:33 PM | #2 |
Re: '59 Gmc exhaust questions
Usually duals on a six are used with a split manifold to enhance the sound of the opposing firing order between front and back cylinders. If you use the stock manifold, a local muffler shop can give you a quote on making up a split pipe and running duals out the back, in front of the back fenders, etc. Or you can sharpen you welding skills, buy a bunch of staight pipe, bends, etc. and make it you self. My personal experience has been they was not enough savings doing it my self vs. having the pros do it a the local hot rod muffler shop. Haven't had any done for six years but think I spent about $350 on material and installation.
Mufflers are subjective, I use Dynomax others prefer Magnaflox or ?? Best is to just go to a rod meet and listen to what folks have and find one you like and ask. Basically size determines loudness and configuration translates into how throaty, poppy or mellow they are. I have shorter 16" on my Chevelle, but put the longest (24" I think) I could on the truck.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
12-06-2014, 04:14 PM | #3 |
To quote OrrieG : Mufflers are subjective, I use Dynomax others prefer Magnaflox or ?? Best is to just go to a rod meet and listen to what folks have and find one you like and ask.
No one could have said it better than that. It isn't what "we" collectively like it is what "you" personally like.
12-07-2014, 09:43 AM | #4 |
If you're going to do it right, go to Clifford Research 6=8 and look at the manifold/header they have for the 270, or go to Speedway and look at the Fenton exhaust manifold.
12-07-2014, 03:30 PM | #5 |
If you really want it to sound good you need to get a set of headers. Here's a sample from EBay:
http://www.ebay.com/itm/216-235-Chev...f0b524&vxp=mtr |
12-07-2014, 03:44 PM | #6 |
Turns out that I don't have a Burnt valve !!! Thank GOD
I'd like to keep original exhaust manifold though?
12-07-2014, 07:04 PM | #7 |
here is the most common way to do it with stock manifold.
