Old 12-06-2014, 04:14 PM   #1
Donaldo
Antenna question
What are your opinions on the 'hidden' or 'invisible' antennas' ?
I see advertisements for some that look like long directional finders and others that are powered (12volt) - do any of them work worthwhile ? , FM stations are available in my area.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 12-06-2014, 04:24 PM   #2
Rude Dude
Rude Dude's Avatar
Re: Antenna question
Most Radio stations broadcast in a digital signal now a days so a lot of Auto radio receivers are synthesized tuners so doesn't need a huge antenna to pick up a good signal unless your running an old AM Radio.
Rude Dude is offline   Reply With Quote
Old 12-06-2014, 05:54 PM   #3
Donaldo
OK thank you, but specifically what of the type of antennas' I asked about ? Or better options without drilling more holes in the truck.
Thanks, Don
Old 12-06-2014, 07:34 PM   #4
Rude Dude
Rude Dude's Avatar
I plan on getting one of these and mounting it under the floorboard
http://www.summitracing.com/parts/mrg-6100
Old 12-06-2014, 08:26 PM   #5
Donaldo
The totally negative customer review on that antenna is why I was asking here - hoping for other options -
or I will have to get the drill out..............:(
Thanks, Don
Old 12-07-2014, 09:37 AM   #6
Speedbumpauto
Speedbumpauto's Avatar
I used a thing called a "tune trapper". Google it. Mounted under the dash close to the base of the windshield. I had already installed the antenna but did some trade out work with a guy to install the receiver and amp. When I picked the truck up, the guy commented "that stupid antenna thing really works". And it seems to, but you know, after you pay for the speed part, the car HAS to be faster. Whether it really works well or not, it's better than putting an ugly antenna on the outside of something I worked that hard on....but maybe it's just me.
Speedbumpauto is offline   Reply With Quote
Old 12-07-2014, 10:10 AM   #7
Indian113
Indian113's Avatar
Rude Dude I have that same one in my S10 and I hate it ! It's very directional and limited range. I also have a hidden one that looks like a ribbon in the fairing of my Harley that works SO much better.
Indian113 is offline   Reply With Quote
Old 12-07-2014, 01:19 PM   #8
_Ogre
_Ogre's Avatar
i have a cheap $9.99 autozone antennae wire tied under the passenger step on my 58
i slid some thin rubber tube over the end when i wire tied it so as not to ground the antennae
shop air compressor timer
Old 12-07-2014, 09:40 PM   #9
youngrodder
youngrodder's Avatar
I too used the Ogre method and it worked great.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-07-2014, 10:09 PM   #10
Highsider
Highsider's Avatar
I have posted these photos in other threads, but just for fun...
Electric, automatic, retractable antenna. Installed in the early '80s:
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 12-07-2014, 10:56 PM   #11
Iceburgh
Iceburgh's Avatar
I have tried almost everything on the market.... I am sticking with Iheart radio
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 12-08-2014, 01:52 AM   #12
Donaldo
I was actually hoping for experience/opinions on hidden antennas, not programming. I did try searching but didn't find an Iheart radio antenna...
Thanks, Don
Old 12-08-2014, 12:58 PM   #13
iowaboynca
iowaboynca's Avatar
LOL...I think Iceburgh is referencing the IHeart radio app on his phone...which is very nice...
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 12-08-2014, 07:36 PM   #14
Iceburgh
Iceburgh's Avatar
Yes Iheart works as an app on your phone. Most radios have a way to hook to your phone by wire or blue tooth.
As far as antenna I spent money on the tune trapper for motorcycles as well as 2 different ones from radio shack. None worked in my area
1953 suburban build
Old 12-09-2014, 07:46 PM   #15
_Ogre
_Ogre's Avatar
what are these apps you guys have on your phones
mine makes calls and T9 texts
Old 12-09-2014, 08:28 PM   #16
Donaldo
How often do you have to rewind it ?
Thanks, Don
Old 12-09-2014, 08:47 PM   #17
joedoh
joedoh's Avatar
I have used a couple, the scosche windshield mount, the dakota digital. Metra made a fiberglass one for a while. mounting those under steel does not work very well but mounting them to the inside of a windshield does work really well. I have had a few cars with the antenna mounted in the windshield or rear glass, aside from being pretty directional with respect to which way you are heading (towards or away from the station) they always worked well.
I had a bunch more typed on antenna theory but it seemed extraneous on the proof read so I pared it down to:
I have also seen guys stick a 1/4 wave aerial under the dash (the ogre method) and as long as you provide the base a ground it can work pretty well (relax, normally your radio antenna input has the outer shield tied straight to chassis ground so just plugging it in does the antenna grounding) but not as well as giving it that plane of the hood to reflect from. as long as you stay in town where the signals are strong, you should be good.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 12-10-2014, 01:12 AM   #18
iowaboynca
iowaboynca's Avatar
You know i remember as a kid out cruising, it was 'shotgun's' responsibility to man the tape deck...and so help me god if you miss "Dumas Walker" one more time you're in the back seat...
