Old 12-08-2014, 11:03 AM   #1
audaciousduo
Pinion angle
Hello all,
Just looking for some opinions on my pinion angle before I commit to a course of action. The truck is a 72 Jimmy with 4" tough country springs in the front, ORD shackle reversal and 2" tough country springs in the rear. The truck sits nice and level with the top on and no longer looks like a dog dragging his hind quarters on the carpet. The shackle flip and converting from an automatic transmission have left me with a 10 degree difference in drive line angle and pinion angle. I'm wondering with the six inch total lift in the back if the drive line angle is too steep for single u-joints?
Option (1) a 10 degree shim from DIY4X4 for under $50
Option (2) cut off and weld on new spring perches for under $50
Option (3) go to a double cardan joint in the rear which will be expensive to have a drive shaft built.
Thanks for your input
audaciousduo is offline   Reply With Quote
Old 12-08-2014, 12:02 PM   #2
argonaut
argonaut's Avatar
Re: Pinion angle
Go with the double cardan joint driveshaft. With the short wheelbase and 4-6" of lift you will operating near the max working angles of the single joints.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 12-08-2014, 07:23 PM   #3
audaciousduo
Re: Pinion angle
Thats what I was afraid of ....... spendy
Old 12-09-2014, 08:45 PM   #4
audaciousduo
Re: Pinion angle
Anyone ever deal with these guys or recommend a supplier?
http://www.dennysdriveshaft.com/c4_4x4_driveshafts.html
Old 12-10-2014, 12:32 AM   #5
dieseldawg142
dieseldawg142's Avatar
Re: Pinion angle
something a little closer to home & no exchange on the buck
they do awesome work, cant say anything but good about them, they built my cardon'ed fr shaft for my 8" lift crew, some of my buddy's are running their shafts as well with zero probs
http://www.abbyspring.com/driveshafts.asp
dieseldawg142 is offline   Reply With Quote
Old 12-10-2014, 09:16 AM   #6
obijuan
Re: Pinion angle
I used a flange on the output shaft and used a stock 1350 cv from a 99+ super duty truck. Strong and plentiful. You can retube it pretty reasonably. If you're staying 1310 jeep xjs have a good front cv shaft to use.
obijuan is offline   Reply With Quote
Old 12-11-2014, 12:34 AM   #7
audaciousduo
Re: Pinion angle
I'll look into Abby spring and check the not so local wreckers for the other bits.
