70+ ( Old Skool Club )
![]() Join Date: Nov 2003
What is this shield for?
Looking under my hood I see these two "shields" one on each side of the engine near the exhaust manifolds. My truck is pretty original especially under the hood so I'm curious as to what these do or did ?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: What is this shield for?
extra air flow for the rear cylinders
not too many around anymore
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
I've always heard them referred to as air horns. I'm not certain what their function was but to find them still in place is rare, at least the several hundred or so trucks I've looked at:-)
1971 Longbed BB Cheyenne Super 1972 Longbed SB Cheyenne Super 1972 Longbed Highlander Custom Deluxe 1975 K5 4x4 full convertible Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165 Greg Smyrna TN |
I wonder if they were to help keep the exhaust manifolds cool. I've came across many of these cracked manifolds at my local pick a parts, mostly on C20s and camper specials.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Why? Cooling ?
Carpe manana
![]() ![]() Join Date: Dec 2010
Subscribed - haven't seen these before. Haven't noticed any on the "Survivor" engine thread but may have missed them.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Roadtrip!
![]() Join Date: Feb 2003
I believe this is correct...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Moderator
![]() Join Date: May 2007
I see them on trucks all the time. I believe they are to help direct airflow to cool the manifolds as LeeH stated.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Carpe manana
Would 4wd's make use of these? Given a 4wd motor is set back vs. 2wd it appears clearance would become an issue from what the pics show.
If they are to cool the exhaust manifold it blows me away how an engineer would design something like that. My truck has Ram Horns and if I'm not mistaken they had been around for a while by 1972 so GM must have had some prematurely exhaust manifold burn outs to come up with something like this.
![]() Join Date: May 2010
Here are a few other threads. Sounds like they may be a 1972 small block thing.
http://67-72chevytrucks.com/vboard/s...d.php?t=314684 http://67-72chevytrucks.com/vboard/s...d.php?t=208380 http://67-72chevytrucks.com/vboard/s...d.php?t=477584 |
Well so far nothing definitive form this post or any previous post. Cooling the exhaust manifold makes the most sense to me. I guess everyone including me assumes the two holes in the top of these things are for bolting something to them but if if they are shields then those holes are probably there to let air in or out of the shields. If they could be found in service or parts manual we'd have name and that should in positively identifying what they are.
#13 |
My original 1972 had them. Now that I know what there for I wish I kept them
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#14 | |
The holes on top are simply the attaching holes on what becomes the bottom for when it is installed on the other side. I think "air deflector" would be a more accurate term than "heat shield". K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-11-2014 at 01:56 PM. |
#15 |
The holes on the top do not line-up with the holes on the bottom. I think they were designed to make it more difficult to remove the middle 2 spark plugs. Mine are still there and they are a pain.
#16 |
They are air deflectors for the manifolds as stated, and they did not come on big blocks or 4x4 trucks. They were a late addition around 71 and most were removed because they are in the way of almost everything.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#17 |
This Shield protects my Vortec 5.3s aluminum oil pan from rocks and other destructive potentials, home made not OEM
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
#18 | |
![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#19 |
Loves all GMC trucks
![]() Join Date: Jul 2010
I think it may be a deeper thinking concept too. The airflow comes through the engine bay and hits the motor causing turbulence so these may be to direct air creating a draft across the manifold. (increasing velocity maybe?)
I have seen them a lot on trucks here in the Midwest. Its just been my thoughts... I have no idea if its true. They are in the way for almost any thing you wanted to do for sure. LOL
Mike If your helping someone and expecting something in return... your doing business not kindness! |
#20 | |
So, on the R manifold, did you notice if the vehicles that had the cracked R manifold have a heat riser valve? Just curious why this happens. I've see AIR cause this on big blocks. |
#21 | |
#22 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
I think what you're looking at are the manifold covers that are part of the heat stove system used to keep the intake air from frosting up. The hot air around the manifold rises up the tube into the air cleaner and a valve in the cleaner opens to let the warm air into the intake stream.
Here are some pictures.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#23 | |
#24 |
Msgt USAF Ret
I see that in the third picture down it shows the heat stove mounted on the manifold cover and your shield down below it. also on the passenger side there is another shield similar to the left side so they are not part of the heat stove system. I'll have to defer to the other posters for the answer. VV
#25 | |
Moderator
