Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 12-15-2014, 05:14 AM   #1
nitrosport_5
nitrosport_5's Avatar
Planning speaker setups for a 72 k20
In another month or so i will be starting to re-assemble the cab of my truck. I have been truing to find ideas on mounting some speakers in the truck but i have had no luck. to start with i have 2 brackets for the cab corners that will house a pair of 6x9s, but for front speakers i am unsure where to locate them or what size to get. I do NOT want to cut holes in the door. The kick panel enclosures look out of place to me. is there any other option to installing speakers up front? will the stereo setup sound decent with just the 2 rear 6x9s? Thanks in advance for any info.
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 12-15-2014, 10:47 AM   #2
68shortwide
68shortwide's Avatar
Re: Planning speaker setups for a 72 k20
Tank in the stock location or rear framerails? Could put a sub enclosure behind or under your seats. could put some mids n highs in the dash. i plan on building a metal/leather covered console and was gonna hide amps and a set of 4s or 5s in there also.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline   Reply With Quote
Old 12-15-2014, 11:01 AM   #3
slowcpe
slowcpe's Avatar
I personally would not like have just a pair of 6x9s in the rears. It would be like going to a concert, turning around, and covering your ears with pillows.
Put a nice pair of 4" in the dash and they will sound good. I made an enclosure that houses (2) Rockford Fosgate Punch 4".
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 12-15-2014, 11:14 AM   #4
reaper71
reaper71's Avatar
Hey! thought I'd chime in on this..
In a 67 Me and Dad built for a guy a few years back we put his front speakers in the stock vent openings on the kick pans (he was running a vintage air unit so these would not be used) We removed the old flap doors and made our own housings and capped them off. then mount the speakers in the housings. we also put tweaters on the A pillar to balance out the sound in front.
In the rear we used 6x9 in the corners and a sub in the middle of the buckets..
reaper71 is offline   Reply With Quote
Old 12-15-2014, 07:20 PM   #5
nitrosport_5
I've got the tank in the rear. Thinking about a sub behind the seats down the road.
Slowcpe does that setup fit in the stock speaker location or elsewhere? Thanks!
Old 12-15-2014, 09:19 PM   #6
slowcpe
slowcpe's Avatar
Yes I made a bracket so that the speakers sit under the dash in the original mono speaker location.
Ryan
Old 02-17-2015, 09:01 AM   #7
Mike C
Mike C's Avatar
I just did the stereo in my 69 short step. I put a pair of 5 1/4" co-axials in the door PANELS (this is a great option that if you change your mind you just put a piece of aluminum tape over the hole and a new door panel on.) It is easily hidden if you change your mind and it gets the speaker higher up in the door with tweeters closer to ear level. A single 8" sub under the passengers side of the seat makes for the sound below 150 hz and the 5 1/4's crossed over about the same.
There is none of the reverb issues that larger speakers lower in the doors have and because the speakers are screwed into the panel and the door it is very rigid so doesn't vibrate. These have a 2" mounting depth and you might be able to go 1/4" more before interfering with the window regulator mechanism.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-18-2015, 03:32 AM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: Planning speaker setups for a 72 k20
Here are some threads for you to look at with idea's.
http://67-72chevytrucks.com/vboard/s...d.php?t=607314
http://67-72chevytrucks.com/vboard/s...d.php?t=659353
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
