Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 12-16-2014, 02:12 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up 2000 S-10 Truck
Just thought I would add this since I just did it to my daughters truck.
2000 S-10 extended cab:
Neither electric mirror on the truck would work at all. I checked it with a test light and had power to the orange wire into the switch.
I took the switch out and took it a part. I cleaned the contacts with a small piece of scotchbrite and on the mirror select switch I bent the little contacts up good so they would make good connection. Put it back together and both mirrors have full operation again. Just thought some of you may want this tid bit before buying new switches.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
