Old 12-22-2014, 12:54 PM   #1
aod92
aod92's Avatar
Carbureted ls
I see that most of you guys that do the swap have f.I. How many of you guys are carbed and how do you like it? I'm picking up a 5.3 this week for my truck. It will be a weekend cruiser, and every once in a while take it to the strip for test and tune. I Want to go carbureted for the simplicity of it. Any big downfalls of going the carb route that I may be overlooking? Thanks guys!
aod92 is offline   Reply With Quote
Old 12-22-2014, 02:30 PM   #2
windmill
windmill's Avatar
Re: Carbureted ls
going carb is simple,, just buy the msd stuff tho, you can use the chips they supply or do your own timing table built in,, you also can use the map sensor too. has a 2 step system built in too..
I have a mustang with a 6.0 carb runs good 6.4's on motor 1/8 mile
72 swb pickup
http://i124.photobucket.com/albums/p...k/100_0958.jpg
1967 chevelle ss
1966 mustang getting a l33 ls motor
1969 chevy dump truck
1989 mustang 6.0 ls best time of 1.29 at 5.91
https://www.youtube.com/watch?v=JtbooZoGZmQ
windmill is offline   Reply With Quote
Old 12-22-2014, 02:35 PM   #3
aod92
aod92's Avatar
Re: Carbureted ls
Msd is definitely the way I'll go. Seems like the easy way to do it!
Old 12-22-2014, 10:09 PM   #4
crazy longhorn
Fabricate till you "puke"
Re: Carbureted ls
No issues carbed...just plug & play!I am sure that I lost a little of the "magic", that the fuelie has, such as mileage/cold driveabilty? As far as power, I do not feel that I lost anything! I did use the edelbrock intake & box, but will agree with the rest of the bunch, that the MSD box has more features to program, if you are racing? For my street cruiser, I don't need to mess with anything but the plug pills? That rock /stock 5.3,(140,000 miles) with nothing but a fresh grind/springs & gaskets, has enough 'smoke' to twist my old truck sideways, with a tap on the loud peddle Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-26-2014, 09:28 PM   #5
dec010974
dec010974's Avatar
Re: Carbureted ls
hello to all. I have a lq4/th400 with an aftermarket camshaft, springs, and push rods. the problem I have with carbed msd setup is that I don't know how much is left on the table when it comes to tuning/driving my setup. even though it feels fine, I haven't learned the how to set my timing/advance up to go with the camshaft. the engine wont stay crunk with the fuel injection set up. the pcm wont compensate fuel, air, and spark for the aggressive ness of the camshaft. I was told I need to have it tuned prior to me driving it. I hope someone can chime in and tell me where to start. the specs of my cam are
.588I/.588:112centerline:228I/228. the carb I use is holley 750 with vacuum secondary (3310)
dec010974 is offline   Reply With Quote
Old 12-26-2014, 09:55 PM   #6
windmill
windmill's Avatar
Re: Carbureted ls
how are you in the world using both msd and pcm?
72 swb pickup
1967 chevelle ss
Old 12-27-2014, 09:46 AM   #7
homemade87
Re: Carbureted ls
I have a carbed ls2/ls3 top end and love it . It is a screamer . There is no difference in tuning a carb from one to another . Each engine takes a little different tune from the carb . Your best friend is a air fuel ratio gauge. Just cant get it right with out one . You will be shooting in the dark. As for the msd box . The best way is to learn the program and hook up your lap top so you can custom tune . Also adding a map sensor will help part throttle cruise and also help quality of idle . You can always just use the pills that come with it but you will not get the most from you engine either . ls1tech has a carb section with some sticky's that has some good info to get you started . There is a little more to it because of the msd box but it does the same old stuff as the old school tuning method just in a different way . Take the time to lean it and you will love your carb .
homemade87 is offline   Reply With Quote
Old 12-27-2014, 01:14 PM   #8
dec010974
dec010974's Avatar
Re: Carbureted ls
Well to be honest windmill, I just got all the info I needed to properly tune my Holley 3310. Some how it bogs & stumble when I get on the gas pedal. I've been on ls1tech b4 and read thru the threads that pertain to adjusting the timing, but I need to me a laptop. my Ipad just wont due. until then, ill just have to wait. As for now, I'm on the fence about carbed and FI LSx. Both are Cool. windmill or homemade87 pm your phone numbers, unless you you can point straight on this thread. thanks. clark.
Old 12-27-2014, 04:15 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Carbureted ls
My opinion, if your gonna get out a laptop and learn to tune...you could be doing so on the FI. Once you get into adding a MAP, your just edging closer to FI...
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 12-27-2014, 04:56 PM   #10
dec010974
dec010974's Avatar
Re: Carbureted ls
Wow brew. Point well made.
Old 12-27-2014, 07:20 PM   #11
homemade87
Re: Carbureted ls
There is a big difference in learning hp tuners and the msd carb program . I have carb set up and fi . I did most of what I needed on the msd in about a week after doing a little research . I had to spend $500.00 for hp tuners and have had it about a year now and I am just starting to get the hole scope of things . Tuning fi is definitely a learning curve . Don't think the msd and fi are remotely close to the same software. If you want simplicity , pay some one else to set up your tune for fuel injected .
Don't let me discourage you about learning fi tuning . It has been a challenge . I think you will find it to be a lot more difficult than most think .
Also the map sensor is nothing more than the vacuum canister on the distributor on a old carb set up . Just does it in a different way .
Old 01-01-2015, 11:58 AM   #12
RatPoweredTruck
Re: Carbureted ls
Another advantage to FI, transmission control. I'd leave tuning to the ECM since driving conditions are ever changing. Your engine might last longer too because of lesser rich or lean conditions a carb creates. IMHO.
My 2000 3/4 ton 6.0/4L80e is near 300K miles and still running strong in spite of engine rattle at start up. Transmission is holding up as well.
RatPoweredTruck is offline   Reply With Quote
Old 01-01-2015, 07:41 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Carbureted ls
Its a 2000, it will always rattle on start at high mileage. As long as you keep her lubed up, that rattle shouldn't be an issue (just make sure its not the timing chain rattling. If it is, change it). If the noise is from the valves, try seafoaming it and see if they quiet down.
Old 01-01-2015, 11:00 PM   #14
crazy longhorn
Re: Carbureted ls
It is my understanding, that it is the pistons that rattle in the LS engines, on a cold start? They have a very short slipper skirt, & will rock in the bores, with anything over 50000-70000 miles. To compound the problem, the stock engines are positive deck, on the pistons? That and a little carbon build on top , can create a problem! My thoughts....that piston knock , is a double knock, when the engine is cold...gone in a few seconds of warm up. both of my trucks have that cold rattle....the 02 has 165000 on the clock, & the 5.3 , in the longhorn has 138000 on the clock. But it is sure a piston knock (in my trucks). Up for discussion.... longhorn
Old 01-06-2015, 06:46 PM   #15
dec010974
dec010974's Avatar
Re: Carbureted ls
aod92, br3wcity, ratpoweredtruck, its 2015. Its time to enjoy my truck, the way it was meant to enjoy. Bye bye carburetor, FI is the new plan. I wont be going back, I promise, unless I find a 1931 international pick up truck.
Old 01-06-2015, 06:47 PM   #16
dec010974
dec010974's Avatar
Re: Carbureted ls
Its time. FI wild side. A smart guy will be coming next week to tune this puppy's sporadic idling bump stick. everything is done except the final wiring for 12v+ ignition power, 12v+ power ground, and fuel pump relay control. I went through the harness last weekend and found all the needed items in the stock, 5.3 (LM7) harness.
Old 01-06-2015, 07:32 PM   #17
HemiChallenger71
HemiChallenger71's Avatar
Re: Carbureted ls
Longhorn: The piston slap is pretty well known. My 130k mile 4.8 does it on cold start in cold weather for 30sec. Above 30degrees it doesnt do it. I also run 10w-30. I may try 5w-40 rotella and see if it helps.
For you guys with a carb I have a big favor to ask. Can you measure the overall height from the intake valley to top of the carb? I'm debating on carb or FI for my swap and this will help me make my decision. My hood line is low.
HemiChallenger71 is offline   Reply With Quote
Old 01-06-2015, 08:27 PM   #18
aod92
aod92's Avatar
Re: Carbureted ls
What's the main reason your switching to fi? I'm still undecided between the two. I love the simplicity of going carbureted but I'm afraid I'm not gonna like the reliability of it. Going FI is what I really want, but the cost is really holding me back.
Old 01-06-2015, 09:46 PM   #19
crazy longhorn
Re: Carbureted ls
When you say low on the hood line, is it Z-ed, or body dropped? there are some pics of my truck.....probably a page or so down.... longhorn
Old 01-06-2015, 10:32 PM   #20
HemiChallenger71
Re: Carbureted ls
No its going in a '59 chevy bel air.
Old 01-06-2015, 10:54 PM   #21
crazy longhorn
Re: Carbureted ls
Gotcha....sound like a very cool ride also! I can get out manyana, & measure....you want from the valley plate , to the filter mount on the carb? I will say that the truck intake (LS), stands pretty tall, as does the edelbrock intake /carb , on the LS? The shortest intake that you can run is an LS-1, on the gen III ....longhorn
Old 01-06-2015, 11:07 PM   #22
dec010974
dec010974's Avatar
Re: Carbureted ls
To aod92, well it's very simple to run a LSx with a carburetor. Very easy. In my case, my lq4 has a few mods, ported heads, medium sized cam, aftermarket springs and pushrods. With the stock, reflashed pcm(lt1swap.com), the pcm can't properly run my engine. That's where the smart guy comes in. The tuner will read this information from engine through PCM and make changes such to the fuel trims, read data from O2 sensors, adjust timing, idle, and adjust some other stuff I don't know about. Good tuners can make a stock 5.3(lm7), run great. I'm talking 350/hp good. In Miami Florida, I couldn't find that good tuner to make the right adjustments to the carburetor, and adjust the timing curve through the msd box. Remember my lq4 isn't stock. In my case, the carburetor made the motor run, but not great. after I tinkered with it, to get better results, my lack of experience with a carburetor just couldn't get the healthy lq4 to run great. The lq4 booged most of the time and seamed pig rich. In my case it ran ok, but not great. In most cases, once the PCM is tuned & set up from the PCM readings, the info will be saved to the PCM and the engine will run as it was intended too. Great. I just couldn't get there with a carburetor. If you know your around a carburetor, and you are willing to play around with msd box & pills you may get what I missed. I'm very impatient and ready to start enjoying my truck. I want to get everything working as it should so I can enjoy my rat rod. Good luck. If you need help. any help, pm me and I'll help any way I can. Good luck. 2015. Enjoy your truck.
Old 01-06-2015, 11:09 PM   #23
aod92
aod92's Avatar
Re: Carbureted ls
To aod92, well it's very simple to run a LSx with a carburetor. Very easy. In my case, my lq4 has a few mods, ported heads, medium sized cam, aftermarket springs and pushrods. With the stock, reflashed pcm(lt1swap.com), the pcm can't properly run my engine. That's where the smart guy comes in. The tuner will read this information from engine through PCM and make changes such to the fuel trims, read data from O2 sensors, adjust timing, idle, and adjust some other stuff I don't know about. Good tuners can make a stock 5.3(lm7), run great. I'm talking 350/hp good. In Miami Florida, I couldn't find that good tuner to make the right adjustments to the carburetor, and adjust the timing curve through the msd box. Remember my lq4 isn't stock. In my case, the carburetor made the motor run, but not great. after I tinkered with it, to get better results, my lack of experience with a carburetor just couldn't get the health lq4 to run great. The lq4 booged most of the time and seamed pig rich. In my case it ran ok, but not great. In most cases, once the PCM is tuned & set up from the PCM readings, the info will be saved to the PCM and the engine will run as it was intended too. Great. I just couldn't get there with a carburetor. If you know your around a carburetor, and you are willing to play around with msd box & pills you may get what I missed. I'm very impatient and ready to start enjoying my truck. I want to get everything working as it should so I can enjoy my rat rod. Good luck. If you need help. any help, pm me and help any way I can. Good luck. 2015. Enjoy your truck.
Thank you very much!
Old 01-06-2015, 11:59 PM   #24
HemiChallenger71
Re: Carbureted ls
Any measurement would help. Valley plate to carb flange, valley plate to top of carb etc. I'm having a hard time figuring out how much taller a carb an intake would be over the truck intake.
I have measurements for a regular SBC in an x-frame (buddys car) and I believe the LS is approximatley 1" taller.
A carb'ed sbc fits great under the stock hood (duh they came from the factory). If the LS with a carb comes close to the sbc I will go carb because its easier and cheaper for me. I have a lot of experience with carbs. If i stay FI its going to be a lot more expensive by the time i have a dyno tune done etc. I HAVE to keep the factory hood so thats my limitation.
Old 01-07-2015, 12:50 AM   #25
crazy longhorn
Re: Carbureted ls
You have to love this....colder than he!! in my spot in Illinios...BRR! I have an Edelbrock top(intake/carb), & she measures 8" even, from the valley/straight edge on the carb, right where the AF sits down? You need to add2 3/4-3" clearance, for the air filter(minimum) Also, where that engine sits in your ride, may be different? Got pics on that 59? Longhorn
