12-28-2014, 12:49 AM | #1 |
VIN tag question. How bad did I get burned?
I think this may be a lesson learned from being young and dumb. I picked up a '71 a few months ago and deciding to ask questions about this vin tag a little too late it seems... It's obviously not factory. So, any idea as to how it was replaced and has passed state inspection to get titled? Everything I've found as to replacing these says it's illegal AF! Any idea how it got like this? If there is anything I can do about it? Or just jump ship with this one find a new pawn for the truck and hunt down a different truck for myself?
12-28-2014, 12:54 AM | #2 |
Re: VIN tag question. How bad did I get burned?
were you able to get it titled when you bought it? No, that's not original, correct, or anything good - can even see the holes where the previous legit GVWR/VIN tag used to be. Recommend have DMV do a title search and as long as they can confirm it's not stolen, they may be able to issue a replacement VIN. It won't be "chevy-like", but it'll at least be legal. Cross-check the VIN on the SPID in the glovebox, if it's still there - and on the upper channel of the driver's side frame rail, kinda below where the brake booster is (sorta). See what matches - go from there. What you are trying to show above should look something like this one (i.e. it should include GVWR):
12-28-2014, 12:57 AM | #3 |
Carpe manana
Yeah, it looks to be a custom job someone made. Those holes on the pillar are probably original VIN tag rivet holes. What year truck, do you have pics of the glove box door decal (SPID), and what is the VIN stamped into the frame? When transferring a title in-state it's possible no one inspected the truck and the title was issued. Probably won't have similar luck titling it in another state.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
12-28-2014, 01:03 AM | #4 |
I was able to get it titled when I bought it. Is checking to see if it were stolen or not something that is not done in the titling process? Transfered from TN to KY. Though now in VA I am slightly worried about it when the time come as the have a half way thorough inspection (if you don't know anyone in the business lol) Aside from that I had plans to resale the truck after some good work and now see it as a huge strike on any sort of in depth restoration.
12-28-2014, 01:07 AM | #5 |
Nothing in the glove box. I'll check the frame in the morning.
12-28-2014, 02:42 AM | #6 |
It may be a state issued VIN tag using the original VIN. http://67-72chevytrucks.com/Chevyear.html
71 half ton, V8 Atlanta built, etc. |
12-28-2014, 03:42 AM | #7 |
Check the frame number to see if it matches. Should be 1A615715.
The VIN itself breaks down as a 71 C10 V8 pickup built at the Lakewood Assembly Plant (Atlanta, GA) in March of 1971.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-28-2014, 03:44 AM | #8 | |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
12-28-2014, 01:56 PM | #9 |
So I know I'm not crazy I am looking in the right general area, correct? Should be able to see something if it where there by now with as much as I cleaned up? I now it's not like they are stamped lightly so they should be THAT hard to see, if there..., right? Guess it seems I bought a good running donor...
12-28-2014, 02:07 PM | #10 |
the partial vin# is up closer to the steering box
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-28-2014, 02:26 PM | #11 |
Thank you sir! That was the ticket. Basically right next to the power steering pump. Guess I took the break booster area a little too much to the heart haha. Well at least some nervousness has been lifted. Now just need to regroup and figure out what I really want to do with the truck in light of some of this.
12-28-2014, 02:44 PM | #12 |
That definitely doesn't look like any kind of VIN a DOT would issue... and you don't have a title anyway? The only right thing to do would be to get a state issued VIN and title (if VA even does that) otherwise this is only a parts truck.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
12-28-2014, 03:04 PM | #13 |
That is on the cab, correct? Maybe the cab was trashed, someone replaced it with another one. Not that making their own VIN plate was the correct thing to do but it worked for the state at that time.
You can check to see if YOU change the cab can you register it with the correct VIN on the frame AND the different VIN on the plate. What would you have to do to prove that it was legit to get proper registration? I would check with the local motor vehicle department and just pose the question "What do I do if my cab is destroyed and I want to replace it with another used one"?
Terry Soon to be retired and moving to Bristol, TN. |
12-28-2014, 03:09 PM | #14 |
First, you need to understand your state's laws. There is a wide spread misunderstanding that it is illegal to remove/replace a VIN tag. That is not at all what the law in Texas says. In Texas, it is illegal to do so with intent to conceal the identity of a vehicle. Normal removal and replacement during repair and restoration is legal. Knowing the back-up location on your frame to validate the tag is a good idea. Even better would be to buy an authentic reproduction and properly stamp it and affix it with the right fastener. Non-authentic tags are legal, however.
Do a little research on your state's laws, and learn how they are interpreted. NEVER take one opinion as gospel.
Scotty Baccus |
12-28-2014, 03:13 PM | #15 | |
good luck with it
12-28-2014, 03:27 PM | #16 |
Carpe manana
VIN tag removal was a recent topic of discussion on this thread - definitely know your states laws and it may be worth considering other states laws as well if you ever want to sell: http://67-72chevytrucks.com/vboard/s...d.php?t=653663
12-28-2014, 04:20 PM | #17 |
VIN tag tampering is a big NO-NO in California. You "CAN" have your vehicle confiscated by tampering with them. BUT, if you change cabs on a truck and you go through the right steps, it is a NON issue.
I believe that you have to show ownership of both vehicles and then you have to get the correct paperwork and SCRAP the one that you are not keeping. I might be somewhat off be am fairly close that is the end result.
12-28-2014, 04:59 PM | #18 |
Here in WA its up to the State Patrol. You pull in, they check the VIN, you pull out. That was when I imported my cars from Canada, anyway.
What I don't know is if they slam the doors shut and confiscate your vehicle if something is wrong. I can't imagine they let you cruise out of there with a stolen vehicle, and odds are they won't run a VIN for you unless the vehicle is there.
12-28-2014, 07:38 PM | #19 |
My brother always told me (attention to detail). It has proved me well.research first buy later.On the lighter side you could always twin turbo and go wheels up just like farm truck! If you have a title and plates drive and enjoy!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
12-28-2014, 07:44 PM | #20 |
I've lived in Virginia for most of my life and I have never heard of the DMV looking at a vehicle. Not saying they can't or never would but in all the years of messing with cars I never have. Now, you might have trouble with state inspection if an Inspector sees the odd VIN plate and calls their Trooper in. I guess the other issue is the value of the truck with a odd VIN tag.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD 1970 Chevy Nova - Street and Strip Project 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
12-28-2014, 07:54 PM | #21 |
Carpe manana
I'm no lawyer but reading an example state code, this one from Texas, doesn't seem to allow individuals to remove a VIN tag for painting or other purposes. A person commits an offense if they merely remove a tag by my interpretation:
"knowingly or intentionally removes, alters, or obliterates the serial number or other permanent identification marking on tangible personal property;..." Texas Penal Code Ann. 31.11(a)(2)(A) See --§ 10[c] Sec. 31.11. TAMPERING WITH IDENTIFICATION NUMBERS. (a) A person commits an offense if the person: (1) knowingly or intentionally removes, alters, or obliterates the serial number or other permanent identification marking on tangible personal property; or (2) possesses, sells, or offers for sale tangible personal property and: (A) the actor knows that the serial number or other permanent identification marking has been removed, altered, or obliterated; or (B) a reasonable person in the position of the actor would have known that the serial number or other permanent identification marking has been removed, altered, or obliterated. (b) It is an affirmative defense to prosecution under this section that the person was: (1) the owner or acting with the effective consent of the owner of the property involved; (2) a peace officer acting in the actual discharge of official duties; or (3) acting with respect to a number assigned to a vehicle by the Texas Department of Transportation or the Texas Department of Motor Vehicles, as applicable, and the person was: (A) in the actual discharge of official duties as an employee or agent of the department; or (B) in full compliance with the rules of the department as an applicant for an assigned number approved by the department. (c) Property involved in a violation of this section may be treated as stolen for purposes of custody and disposition of the property. (d) An offense under this section is a Class A misdemeanor. (e) In this section, "vehicle" has the meaning given by Section 541.201, Transportation Code.
12-28-2014, 08:12 PM | #22 |
Old member
You can read these post all day long, but in the end until you talk to the proper people (DMV) your just reading stuff. Sorry guy's but the state of Tx has nothing to do with his question.
Best thing is call the DMV in your area and ask. That will be the start of the process. As stated though the face value of your truck resale value will not be as good as you once thought.
12-28-2014, 08:15 PM | #23 |
Carpe manana
Andy you are correct but I can tell you that had I not known the NM regulations regarding year of manufacture plates I wouldn't have been able to put a YOM into use because the DMV folks were clueless. Sorry to hijack the thread.
12-28-2014, 08:33 PM | #24 | |
Old member
I can agree with and that is good info. The stuff about what one state will are want do is just talk. Knowing your trucks vitals is a must when talking to a DMV person. But just in general telling him what they will are want do is worthless info. He needs to call and find out what he needs to do from the DMV for his state. That is the answer and the only way for him to know for sure.
12-28-2014, 09:04 PM | #25 | |||
I can imagine it may be hard to give an idea with so many potential variables. Any idea how much it could affect the bottom dollar (if all hypothetically goes well and I get at least a state VIN so it is more legit that it is now). |
