Roadtrip!
![]() Join Date: Feb 2003
1967 gmc hubcap ID...
Trying to determine if these would be correct on my 67 gmc. They are aluminum, not steel. Any help or info is appreciated. I didn't pull the cap off yet, but can i assume these would be for a nub style wheel?
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: 1967 gmc hubcap ID...
Yes, those are correct for 1967 GMC. Your wheel appears to be the standard nub style that accepts the regular 10 1/4" cap. Many of those '67-'68 caps look the same from the outside, but the backs sides can be different if wheels are clip type. Those are not aluminum, they are chrome over brass. They are notorious for splitting on the edges, be careful when removing. Those should shine up again after a little scrubbing with a very wet SOS pad.
![]() Join Date: Feb 2014
This is the best site I have found for GMC cap ID. http://gmcguy.com/gmc_hubcaps_wheel_..._and_rims.html
Bruce |
A good, cheap way to clean up chrome is aluminium foil and soda pop- I'm told that diet Pepsi is best, but they guy that told me drinks that exclusively. Rub the crumpled foil over the surface, using the soda as a wash/lube. Amazing results, especially if it's got specks of corrosion on it.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
#5 | |||
Roadtrip!
