Old 12-28-2014, 11:26 PM   #1
roxxx
LS motor & 4L80E 4x4 swap links and questions
I imagine there are links and posts galore I just cannot find many
I have a 1972 4x4 swb manual that I am either going to put a NV4500 in or what i would really like is a LS6 with a 4L80E
Just looking for a few links to determined if it is worth the effort to do the swap to an auto
roxxx is offline   Reply With Quote
Old 12-29-2014, 03:43 AM   #2
andrewmp6
Re: LS motor & 4L80E 4x4 swap links and questions
One problem your not thinking of is the t case,The newer trucks like the 4l80e is in uses the wrong side drop t case.I believe you can use a np241 from a 88-91 k5/suburban or use a adapter kit and run a np205.And again using the nv4500 you will probably be stuck doing the same thing use a np241 or a adapter kit.As far as swap parts http://pacificfabrication.com/63-72-...ssmembers.html and http://dirtydingo.com/store/product_...oducts_id=1408 both are a engine crossmember.The trans/tcase mount your kinda on your own to rig up,Most take a stock one and move/ cut and mod it to fit.
andrewmp6 is offline   Reply With Quote
Old 12-30-2014, 12:32 PM   #3
First c10
First c10's Avatar
Can you bolt up a np 208 to a 4L80 or 4L60? Aren't the 4L60 and 80 just an OD version of the th350/400.... So you can run a newer ls motor and a matching 4x4 trans to a older TC to get the passenger side TC drop?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-31-2014, 12:10 AM   #4
andrewmp6
The 4l60 you should be able to use any t case off a 700r4,The 4l80e i have no clue on what will fit out not.
Old 12-31-2014, 12:39 AM   #5
joeydurango
joeydurango's Avatar
4L60, NP205, no problem. Advance Adapters makes what you need. Sorry, no part number...
Pac Fab's LS crossmember works well, so long as you have at least 2" of lift.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 02-02-2015, 01:37 PM   #6
youngblood78
I know a 208 from a sm465 will bolt right up to a nv 4500
94 Silverado 1500 ext. Cab short bed 350 nv4500 (factory)
78 K20 350 (soon to be 400sbc if I can find one) sm465 205 dana44 14bff 6in lift on 37" militarys
youngblood78 is offline   Reply With Quote
Old 02-02-2015, 07:26 PM   #7
bhammer
I'm just about the jump into this part of my build. I picked up an LQ9 6.0 and a 4L80e to put in her for $2000 for the set. Looks like the advance adapters is a must have to mate to my np205. Anyone have any pictures of what they did with the Trans/Trans case crossmember to make it work? I think that's my next order of business. I can't wait to get this puppy in place! I decided to put a tuff country 2" spring lift on mine just to make sure I had clearance. Just sonething you may want to check out. I also heard the engine crossmember has to be moved up an inch to get everything resting in the right spot. I also heard there's plenty more room to move it up if you like. I'll def be posting some pics of her once I get to that stage. Good luck and keep posting on your progress, I'm sure I'll run into some problems. Fingers crossed.
bhammer is offline   Reply With Quote
Old 02-02-2015, 10:10 PM   #8
slotard
Wow, that's a nice deal on the engine/tranny. Mileage? Is that including accessories, ECM, etc? I'm keeping my eyes open for something similar...
1973 C20, 350/350
slotard is offline   Reply With Quote
