Old 12-29-2014, 05:28 PM   #1
54blackhornet
54blackhornet's Avatar
Charcoal Canister Removal Question
Can any one explain the charcoal canister removal procedure. I know you will need a vented gas cap, but what about the vacuum ports on the carb. I read the canister goes bad over time, can you substitute one from a later model GM truck ? This is all aimed at eliminating a vacuum leak on my 350 with factory intake and original Quadrajet......
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-29-2014, 07:52 PM   #2
Crabass
Re: Charcoal Canister Removal Question
Isn't the canister just a controlled "leak" anyway, and won't a vented tank condense more moisture into the fuel than a closed system? Inquiring minds want to know, so those of you with knowledge please share.....
Crabass is offline   Reply With Quote
Old 12-29-2014, 11:22 PM   #3
In The Ten Ring
My dad's truck ran just fine for 20 years with the canister unplugged and the hose simply taped shut.
In The Ten Ring is offline   Reply With Quote
Old 12-30-2014, 01:00 AM   #4
Unionwelder
Unionwelder's Avatar
Agreed, 3 trucks I've had with canisters were disconnected long before I got them, never an issue. Honestly couldn't even tell you what it was for up until a couple of years ago.
-Sterling
GIG EM' AGGIES!!!! WHOOOOOOP!!!!!
"Whether you think you can or think you can't, you're
Right." -Henry Ford
1972 chevy lwb
1934 ford p/u
Unionwelder is offline   Reply With Quote
Old 12-30-2014, 09:54 AM   #5
cdowns
cdowns's Avatar
If you just disconect the hoses to the canister no vented cap is required
Old 12-30-2014, 10:33 AM   #6
MARKDTN
Canister purge is not such a bad thing. I would buy a new canister and be done with it.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is online now   Reply With Quote
