01-01-2015, 09:48 PM | #1 |
Tire sizes for 15" steel wheels on the front? Help!
Hello. Tried to search for this answer but there is not really a clear one available. So, I have 4 - 15X8 steel wheels. I am wanting to put them and some tires on a 1968 chevy stepper.
Thinking 275/60/15 for the rears and maybe the front but I'm unsure. Thought the same size for rotation reasons, then another option is a slightly shorter and narrower tire for a staggered look. What is the performance out there around this subject? Fats and skinnie/shorter set up or same all the way? Any front tire suggestions or recommendations for the fronts? What would you put on yours or already have on your? If you have something set up and pictures, it would be helpful. Thanks guys.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
01-01-2015, 09:58 PM | #2 |
Re: Tire sizes for 15" steel wheels on the front? Help!
I love the big/little look, but it sucks if you plan to put miles on them. I'm building my '67 with matching tires & wheels, and also have a pair of drag radials on 10" wheels for local craziness.
You didn't mention if your truck sits stock height or how much drop, if it's lowered. Your answer on tire size will pend on that
01-01-2015, 10:34 PM | #3 |
The truck is lowered 3" in the front and 5" rear. It's a spring only drop. Still have plenty of room in the wheels wells. I plan on driving it anywhere from 2500-5000 miles per year. It's not my daily driver.
01-02-2015, 01:47 AM | #4 |
I went with BIGGINS all around. 295 50 15's in every corner, I can rotate them and also have a great ride believe it or not as those things just drift over potholes like they dont exist where as the skinier tires I ran before caught them and always felt like a hard hit.
just my 2 cents worth. Darren
1967 C10 Shortbox 1971 Monte Carlo SS buckets and console #'s car 1970 350 Monte Carlo bench seat 1970 El Camino SS Last edited by 1971_CST_C10; 01-02-2015 at 01:53 AM. |
01-02-2015, 06:29 AM | #5 |
Nice truck and good info on the tires. Thanks.
01-02-2015, 05:54 PM | #6 |
Step sides have much smaller wheel wells than a fleet. Just how low it is depends on how much tire you can get in there and offset on the wheels plays in.
Assuming the 4" backspace on the 8" rim (Thats like a +12mm offset) you can probably run the 275. But they have a LOT of sidewall bulge and remember that you have the narrower (by 3/4" per side) axle which gets you back in towards the step side inner bedside. I've got 275 55 17 for the back of my 69 short step with 5" backspacing 9" rim, but I'm going to 5 lug using a 71 axle to get the wheel out a little. I hope all this happens next week and will try to post pics. I've got 235 55 17 for the front on 8" rim.
01-02-2015, 06:00 PM | #7 |
275's on 8 " wheels are pretty short , I have run that on the back , with 235/70's on the front , but on a narrower rim , on my 69 (now sold) Spring drop in front , blocks rear , would have liked it a bit lower in the back
01-02-2015, 06:02 PM | #8 |
Another pic of a members truck , I think it had 265/70's on the rear but I'm not sure
01-03-2015, 05:41 PM | #9 |
Anybody else got some insight into what will fit under the front and rear of a stepside that's lowered 3" in the front and 5" lower in the rear.
01-03-2015, 06:31 PM | #10 |
How much work do you want to do? You can get a BIG tire if you are willing to cut the bed floor a little and the bedside for narrowed fleet wheel wells.
Deciding how low you want your truck, making sure rear axle is centered, knowing backspacking on wheels you want to run, and then hitting the ol' tape measure. Remember, a 275 is a totally different size and shape in a 275 55 17 than it is in a 275 60 15. If you are going to run the wheel you have now with the height you are currently at, just measure the clearance you have inside and out and try and extrapolate to a wider size. 275/25.4= 10.9" (25.4 mm per inch), figure that is the width on the tire at the sidewall bulge giver or take, mounted probably on a 9" wheel. On an 8" it will be less, and a 10" more. 275/25.4=10.9*.6(aspect ratio, 60 series)*2(sidwall top and bottom)+15(rim diameter) gives you a 28" tire height, but that too depends on the rim width you choose. Search also all the tire size short step threads you can find, there are a bunch out there. What is the backspacing on your wheels? What tire is currently on the truck? How much clearance from the sidewall to the inner bedside now?
01-03-2015, 07:25 PM | #11 |
Neil, I'm running 265/50/15 on 15x8 rims. 4 1/2 inch drop in the front and 5 inch drop on the rear. I'm running a 3 inch drop coil w 2 inch drop blocks.
Scott |
01-03-2015, 08:21 PM | #12 | |
The wheels I have are 15x8 with a 4" backspace. The current wheels are the stock 15x6 with 4" backspace. I'm thinking that I should be fine with the 275/60/15 but may have to go with the 265/50/15. Anybody else have some valuable input. I really don't wanna add inner fender wells to it. Trying to keep it stockish looking. Thanks guys lots of good info.
01-03-2015, 08:23 PM | #13 |
I forgot to mention I have a 3/5 drop on it now. Don't think I'm go any lower for now.
01-03-2015, 08:59 PM | #14 |
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
01-03-2015, 09:40 PM | #15 |
69 C-10 step side, I've got 285/70/15 on a CUCV 8' wheel on the back and 235/70/15 on the front. truck has 1.5 coils cut from the front and chevelle lowering springs on the rear.
01-03-2015, 09:51 PM | #16 | |
Quit if it's not FUN!!!
I drive my truck about 20K a year (daily driver). The whole big & littte look haven't caused me any problems so far. I got 45,000 miles out of the fronts and about 35,000 out of the rears, including three trips to Pigeon Forge, an all-night trip to Daytona, Asheville twice and Charleston,S.C. I personally like the "deigo" look and if you want it, go for it. It's your truck!!
MY MOTTO: Eat it all up, Wear it out, Use the last few drops, Spend all you've got, Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life ! . Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee) |
01-03-2015, 09:59 PM | #17 |
That's a good looking stance on your truck tobyarnot
01-03-2015, 10:22 PM | #18 |
I have a 67 Step side and I am running 275/60/15 front and rear. Mine is also dropped 3" front and 5" rear. I like the look of it, looks beefy and takes up the wheel well area. I always like running the same size front and rear, not only for rotation purposes, but I also just like the look.
1967 Chevy C10 Stepside SWB - 350/700r4 |
01-04-2015, 02:05 AM | #19 |
I'm doing the same on my 68 - wheels up front ar 7". Very happy with the look and performance. Like the staggered look.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-04-2015, 02:15 AM | #20 | |
Again great color om your truck.
01-04-2015, 02:17 AM | #21 | |
01-04-2015, 02:17 AM | #22 |
No problem! glad to help out.
01-04-2015, 02:19 AM | #23 |
Awesome truck. Love that color.
01-04-2015, 02:19 PM | #24 |
Here's mine 235/70/15 front & 285/70/15 rear
01-04-2015, 02:36 PM | #25 |
These are 275/60/15 all around with a 2/4 drop.
Sorry, I missed the "step side" part.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
