01-04-2015, 03:27 PM | #1 |
Used black blazer carpet.
I am changing blazer over to saddle carpet and I figure there is life left in this carpet set. This is the full blazer set. I vacuumed it but didn't spent much time. It will clean up better than it is. It has a foam backing on it. It is not perfect but driver quality if you can look past a couple of holes or looking for a deal this is for you. This was cut around a roll bar in the rear. I think a lot of that would cover up if someone had rear side panels installed. There is a hole next to front right driver side seat mount where they had a fuel valve. There is also a 5 or 6 inch tear next to transfer case shifter, that could easily be sewn together. There is surface rust spots that were under door sills. Those will also be covered by your sill plates. $115 shipped, that also covers paypal feessold
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 Last edited by Ridnhi; 01-04-2015 at 10:30 PM. |
01-04-2015, 03:28 PM | #2 |
Re: Used black blazer carpet.
Rear section
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
01-04-2015, 03:29 PM | #3 |
Wheel wells.
01-04-2015, 04:38 PM | #4 |
If you can do 100 shipped I will take it let me know
01-04-2015, 09:59 PM | #5 |
Meet me in the middle at $107 and it will still cover paypal fees.
01-04-2015, 10:01 PM | #6 |
01-04-2015, 10:13 PM | #7 |
payment sent thanks
01-04-2015, 10:30 PM | #8 |
payment received, carpet sold!
