Old 01-05-2015, 07:56 PM   #1
Blazer80
1980 k5 blazer 2wd conversion
Hi everyone. I started this project back around April. I had a k5 tub, a 4x4 frame and a c10 parts truck. I looked for a 2wd k5 but here in Michigan they are far and few between. So I decide that I would make my own. I did a lot of research before I started and still am. This is a slow steady project. I'm aiming for 2 years to have a running moving k5. Hopefully it will be DD able. Right now I have all the big things.
1980 k5 tub $150
4x4 k5 frame $0
Parts c10 $100
2 Full quater panels $150
Vortec 5.3 $500
4l60e $150
Front end parts $100
Blazer80 is offline   Reply With Quote
Old 01-05-2015, 08:05 PM   #2
Blazer80
Re: 1980 k5 blazer 2wd conversion
This was after 40+ rivets removed. Got all the 4x4 stuff out
Old 01-05-2015, 08:12 PM   #3
Blazer80
This is the parts truck that I pulled the rear suspension, axle, front suspension and front clip.
Old 01-05-2015, 08:15 PM   #4
Blazer80
After about 2 solid days of measuring I got the front and rear suspension in.
Old 01-05-2015, 08:28 PM   #5
Blazer80
Flipped the rear axle and painted the back half of the frame.
Old 01-05-2015, 08:30 PM   #6
Blazer80
I blocked up the body by myself to roll the frame under
Old 01-05-2015, 08:32 PM   #7
Blazer80
Finally got the body on the frame. Now I'm ready to strip the interior to get the replacement floors in.
Old 01-05-2015, 09:35 PM   #8
flashed
Im in to see the rest .
flashed is offline   Reply With Quote
Old 01-05-2015, 10:35 PM   #9
UKNOWME
UKNOWME's Avatar
Wow, great job! You may beat your 2 year deadline at this rate.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-05-2015, 10:49 PM   #10
Blazer80
Thanks, right now I'm just trying to get the cheap stuff done. All my money is going into my first turbo hayabusa build right now.
Old 01-05-2015, 11:15 PM   #11
Willowrun
Willowrun's Avatar
Cool to see someone frim mid-MI as I was born and raised in Bay City. Are you looking for a lowered 2wd Blazer or close to stock height? I ask because it lookes like you used the 4x4 rear hangers/springs which won't net much drop even with the flip.
Old 01-06-2015, 03:53 AM   #12
BaggedRanger
BaggedRanger's Avatar
Don't forget that the 4x4 front spring mounts are actually different than the 2wd mounts. I'm actually in the process of swapping frames right now because my 2wd one is bent and I found a 4wd one to replace it with. The bottom of the front 2wd spring mount is even with the bottom of the frame and the 4wd one is lower than the frame rails.
BaggedRanger is offline   Reply With Quote
Old 01-06-2015, 07:01 AM   #13
Blazer80
I'm want it lowered but not slammed right now. The 56 inch spring pack is out of the c10. The hangers are 4x4 ones but used those just because they were on the shelf ready to go. I want to get the motor/transmission and front clip on. Then play with ride height from there. Thanks for the heads up on the spring hanger. I didn't know the front one was different.
Old 01-06-2015, 09:51 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
cool ,getting some of the big stuff done right away
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-06-2015, 11:22 AM   #15
68Timber
I know the pieces fit
68Timber's Avatar
Welcome to the site! That's one hell of a good start, nice progress.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-06-2015, 12:03 PM   #16
Blazer80
Thanks everyone. This stuff I find easier. The hard part will be all the body work and breaking done the engine harness myself. This will be my first crack at serious bodywork. Busier can you post some pictures of your 2wd blazer?
Old 01-11-2015, 02:36 PM   #17
Blazer80
So I started ripping the interior out of the blazer. The rust is worse than I thought. The floor, rockers and quarters are rusted bad. The whole side is sagging at least 1/2 inch. Does anyone know where I can find the correct dimensions so I can start rebuilding this.
Old 01-11-2015, 09:53 PM   #18
68Timber
68Timber's Avatar
Click on my username and profile links, there's a pic there. Right now it has the engine out.
Can you post pics of the rust?
John
74 Honda Z50 build
Old 01-11-2015, 11:03 PM   #19
Blazer80
Picture of the rocker
Old 01-11-2015, 11:05 PM   #20
Blazer80
The inside corner that always rusts
Old 01-14-2015, 12:38 PM   #21
68Timber
68Timber's Avatar
I haven't fixed rust like that but check out russgt's thread on his 76, he made similar repairs on his truck.
John
74 Honda Z50 build
Old 05-20-2015, 04:16 PM   #22
made2drag
made2drag's Avatar
very nice so far
made2drag is offline   Reply With Quote
Old 06-25-2015, 04:17 PM   #23
made2drag
made2drag's Avatar
any updates?
Old 09-01-2015, 09:21 AM   #24
edward61
Any updates ?
edward61 is offline   Reply With Quote
