01-09-2015, 06:23 PM | #1 |
performance exhaust help
Hi all. Long time member, first time poster. I'm looking for opinions on quiet performance exhaust and mufflers. I don't mind the truck getting throaty when I pour the coal to her I just don't want my neighbors windows rattling at 5 am. I have a fresh 350 with thorley headers I'm about to install in my 72 4x4 and I'm hoping for the best of both worlds. Not to loud and good performance. Any suggestions? Thank you in advance!
01-09-2015, 07:18 PM | #2 | |
Re: performance exhaust help
01-09-2015, 07:51 PM | #3 |
Thank you, you're the second person to mention magnaflow.
01-09-2015, 08:37 PM | #4 |
Dynomax Hemi Turbo mufflers. 2 1/2" in and out in a 20" case. I have them on the Jimmy and they sound great when you're getting on it, and have a near stock sound level at idle. No drone, a great performance muffler. And even better, they are relatively inexpensive.
I'd put them on my Camaro as well if they weren't so darn long!
01-09-2015, 08:52 PM | #5 |
Personally I like to run a single. You could go the dual 2.5s into a flowmaster Y then into a 3'' Magna Flow then out the back 3''
01-10-2015, 11:48 AM | #6 |
I just put some Sumitt brand turbos on my truck I did have a Dyno max on it that lasted about a 1 1/5 yrs. The sumitt brand is the same as a Dynomax a little cheaper also.Have been told the street strip is the same as Flowmasters 40.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
01-10-2015, 11:50 AM | #7 |
I just put some Sumitt brand turbos on my truck I did have a Dyno max on it that lasted about a 1 1/5 yrs. The sumitt brand is the same as a Dynomax a little cheaper also.Have been told the street strip is the same as Flowmasters 40. I put this on my 01 Silverado has a nice idle tone and throaty at wot
01-10-2015, 12:00 PM | #8 |
I put Flowmaster 70 series mufflers on mine (Dual 2.5" dumped before the axle) And I LOVE them. Even with a fairly big cam, they sound mellow at idle and are nice and quite at all different cruising speeds. Never any drone. They are big mufflers, which makes them a tight fit, but worth the effort in my opinion.
1970 SWB Build |
01-10-2015, 12:04 PM | #9 |
Installed a 2-1/2" system from the Doug Thorley Tri-Y headers back several years ago on my elephant, that was a mistake, raised the torque range higher than I wanted. I wish I could find the link that stated 2-1/4" is more than enough for a small block chevy and anything more you lose the scavenging effect of the exhaust to work properly. A 2-1/4" pipe will flow 600cfm even with a very large carburetor you would never exceed the capacity of two 2-1/4" pipes...
http://www.exhaustvideos.com/faq/how...pipe-diameter/ Last edited by C20ELEPHANT; 01-10-2015 at 12:14 PM. |
01-10-2015, 01:25 PM | #10 | |
01-10-2015, 06:43 PM | #11 |
Something is wrong if those mufflers only lasted a year and a half. My Hemi turbos have been on the Jimmy since the last millennium. And they sound and look like they did when they went on except for a gear oil ring from the blankety blank 12 bolt pinion seal that used to be in it...
I have Flowmasters on my Camaro, the first generations ones bought in 1985, and I'm getting ready to put some Magnaflows on my short bed only because I already have them from a parts truck (6" round body) but the answer to quiet power is the Hemi turbo muffler if you have room for the 20" case.
01-10-2015, 11:02 PM | #12 | |
1967 Chevy C10 Stepside SWB - 350/700r4 |
01-11-2015, 01:52 AM | #13 |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-11-2015, 07:52 AM | #14 | |
