01-10-2015, 09:47 PM | #1 |
Msgt USAF Ret
How our starters work
This may help a lot of you understand how the starter works and be able to trouble shoot them.
The starter cycle starts with the key switch turned to the ST position and power is routed via a 12 gauge purple wire to the neutral safety switch on automatics, and to a neutral or safety switch on the transmission, and some times on the later models, to a clutch switch. From there it goes through the firewall block to the S terminal on the starter solenoid. The solenoid is an electromagnetic device that also acts a relay. The electromagnetic function pulls the starter bendix lever and throws out the starter gear to engage the flywheel. At the same time the contact washer in the solenoid inside near the rear, moves to the rear and joins the two main terminals on the starter. The battery cable at the top and the starter field terminal at the bottom. Note the red arrows. This feeds battery power to the starter windings through the starter brushes and spins the starter armature turning the starter gear and the flywheel. When the key is released the key switch goes to the ignition position and releases power to the solenoid and a spring inside the solenoid returns it to the forward position breaking the contact on the two main terminals for the starter and the cycle stops. shown below.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-10-2015, 10:18 PM | #2 |
Old member
Re: How our starters work
VetteVet you are just amazing man! Great write up. This needs to be put in the electrical stickeys!
01-11-2015, 12:33 AM | #3 |
Nice but the large + cable doesn't go through the junction block as suggested in pic #1.
01-11-2015, 01:48 AM | #4 |
Great info
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
01-11-2015, 08:23 AM | #5 |
My '68 with a 250 6 cyl starter will work good when the air temperature is warm but on a cold morning the starter just spins freely. If I keep bumping the key over and over it will eventually work. I can get it to work faster by holding the key in the start position with the starter spinning freely for about 10 seconds then when I let off the key and turn it again it will work. Does this sound like the solinoid? Thanks.
01-11-2015, 09:13 AM | #6 |
VetteVet, could you clarify a few a few things, haven't kept up on this these starters in years. What starter type is equipped on my 1982 as opposed to the one a friend told me to purchase, memory fades been installed for 5+ years now. I think it came off a about 1990's truck and is substantially smaller in body size and brings the solenoid further away from the heat of the header and a lot easier to install in the limited space....
01-11-2015, 01:04 PM | #7 | ||||
Msgt USAF Ret
The plunger is not directly connected to the solenoid but rather it floats inside the solenoid body. If the voltage is low on the battery or the S terminal the solenoid windings will not have enough magnetic power to pull the plunger far enough to engage the starter gear. Then we get the dreaded click, click, click, that we love to hear. In your case the relay in the solenoid will engage the contacts for the starter windings and cause the starter to spin without allowing the plunger to move the Bendix gear into the flywheel. When it's warm outside or after you've spun the starter several times and warmed the solenoid, The plunger will move freely enough to engage and it then works. In short if you have a good clean connection on the starter S terminal and you're getting enough voltage to the solenoid, and it still won't engage then you will need to replace the solenoid. The next time it happens you should try jumping from the large post on the solenoid to the S terminal and see if the engine turns. Use caution it may start and move the truck. If it still acts up then the solenoid is bad but if it works every time then the wiring to the S terminal needs attention. We have several threads on here to explain how to wire a remote solenoid, which will give you full power to the S terminal. Post in the electrical section if you are interested. Quote:
HTH VV
01-11-2015, 01:35 PM | #8 |
VetteVet, thanks for the info, writing it down cleared some cobwebs (more than cobwebs actually) and I believe I purchased it from AutoZone. I'll look through some receipts tonight, if I find the part number and post it for the rest of the guys having issues with heat soak especially the solenoid. The motor is a small block 350 not sure of the ring gear count...
Found it DL9990S Posted here also... http://67-72chevytrucks.com/vboard/s...d.php?t=286857 Last edited by C20ELEPHANT; 01-11-2015 at 02:05 PM. |
01-11-2015, 02:31 PM | #9 |
Vettevet
Thanks for taking the time to do that. It is great to finally understand how it works.
72 Shortbed fleetside 402 BB, AC, Posi 72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new 66 Chevy Caprice 2 dr 74 Honda CB750 New Palestine, IN |
01-11-2015, 07:36 PM | #10 |
Vet,
Thanks for the detailed write up. I don't have any starter issues right now, but this one is going into the "personal library" for future reference. Once again, very educational!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
01-11-2015, 07:52 PM | #11 | |
http://www.acdelcotechconnect.com/ht...tart_pg260.jsp PG260 Starter Light Duty V8 Gasoline Engines to 7.4 liters, Passenger Cars, Vans, Small Trucks, and Marine ACDelco's Planetary Gear Drive (PG260) offers superior performance in a starter with exceptional durability. The PG260 is suitable for V8 gasoline engines of up to 7.4 liters for passenge cars, vans, trucks and marine applications. The 4-pole, permanent magnet field consists of shunted Magnequench magnets mounted inside a zinc-chromated frame. No field coils are required. The armature is banded, impregnated and balanced for high performance and durability. The armature drives the planetary gear set, which in turn is connected to a roller type overrunning drive. The solenoid is sealed with an integral cover for maximum reliability with minimum weight, yet is still serviceable. Four long-life brushes are used in radial brush holders with torsion springs. All brush rigging materials are corrosion resistant. Figure A Specifications: System Voltage: 12 Volt Rotation: Clockwise Mounting: Flange or Pad Mount Performance: 1.7 KW Weight: 3.5 lbs. Amazon ACDelco 323-485 GM Original Equipment Starter Motor, Remanufactured |
01-11-2015, 08:04 PM | #12 |
Thanks for posting.
01-11-2015, 09:46 PM | #13 |
I'm not sure I like those drawings for the Delco Solenoid. I couldn't find a better drawing.
A Delco starter Solenoid has two windings. A Pull-in winding and a Hold-in winding. The Pull-in winding is a high-current winding because it has to do the work of pulling the plunger and moving the lever and gear. The pull-in winding is connected to the "M" post and is grounded through the motor windings and brushes to ground, inside the motor. The Hold-in winding is a low-current winding, because the work of pulling the plunger has already been done. The Hold-in winding is grounded to the body of the solenoid. When the Hold-in winding is holding the large washer against the two contacts, the Pull-in winding is shorted out and no longer drawing any current.
'67 GMC 2500, 292, 4spd, AC |
01-11-2015, 11:19 PM | #14 | |
Msgt USAF Ret
01-11-2015, 11:50 PM | #15 |
I like the last one on the bottom. Very clearly drawn and correct.
01-25-2015, 11:31 AM | #16 |
I replaced the starter on my truck and it still spins freely the first time I hit the key. She second time I try it cranks the engine great but it makes a weird noise. I am getting full power to the S terminal and even tried jumping it over with a screwdriver. It engages almost always now except for the very first time you hit the key. Does it need to be shimmed? There were no shims in the starter I took off. Thanks for the help.
01-11-2023, 01:15 PM | #17 |
When the starter spins but doesn't engage the engine, the most likely cause is a bad starter drive (sometimes called a Bendix). It is a one way clutch. When they get worn the gear just spins & doesn't turn the engine. If you have some mechanical expertise, you can replace it yourself & clean up the starter & replace the brushes if needed. This is better than some of the "rebuilt" starters you get now. Of coarse if you get it open & its all burned up inside it is time for a replacement.
George |
01-11-2023, 08:54 PM | #18 |
I had no idea of the pull in and stay-in windings of the coil. Great documentation.
What I didn't see mentioned it when you let go of the key the fork is retracted by the spring. The spring pushes on the fork actually acts as a brake. It stops the armature from spinning any longer than necessary. This keeps the brushes from wearing prematurely. Cheers |
01-12-2023, 11:54 AM | #19 |
[subscribing]
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
