01-11-2015, 11:42 AM | #1 |
Gasket @ fuel line/carb?
'68 Chevy C10 '06 Saleen Mustang #725 (Convertible) '04 Infiniti G35 '01 Infiniti QX4 |
01-11-2015, 12:15 PM | #2 |
Re: Gasket @ fuel line/carb?
Fuel inlet gasket. I bought mine from auto zone.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
01-11-2015, 01:44 PM | #3 |
Ok... I bought a new fuel inlet gasket & it's still leaking. The new inlet gasket isn't exactly the same as the old one. The old one is a coated metal ring. I'm also leaking at the fuel line/fuel pump (out) connection. Is there something I'm missing here? It was not leaking like this a few days ago. Also, does the brass type fuel filter, that's behind the fitting pictured above, have a specific direction it has to go in? ...as soon as I can get her to stop leaking, I think she'll be road ready.
01-11-2015, 04:58 PM | #4 |
Where exactly is it leaking?
On the gasket, the brass fitting or the hose? You could double up on the gaskets. The filter goes in with the open end towards the outside. |
01-11-2015, 05:24 PM | #5 |
It's leaking around the threads of the fuel line @ the fuel pump, & between the carb & fitting. ....FYI its a Monojet 1 barrel of a I6 (250).
01-11-2015, 05:39 PM | #6 |
I am a Referee of life.
I had that same leak at the carb and couldn't get it to stop. I decided to replace the fitting that holds the spring and filter in but couldn't find one at the LAPS. Finally realized that the guys who race use carbs and went to the local speed shop. They fixed me right up. The other end could be threads ,fitting, flare or the inside of the fitting on the fuel pump. It could also be a crack in the fuel line. Close inspection should tell you which.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-11-2015, 06:47 PM | #7 |
Doubled up the gaskets & replaced the line. Problem solved. Thanks guys
