Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 01-11-2015, 11:13 PM   #1
UKNOWME
UKNOWME's Avatar
Edge Insight CS Monitor 83730 and Edge Turbo Timer 98604
Both items new in box
Asking 200.00 for the CS-SOLD
Asking 100.00 for the Turbo Timer
Will sell separate or together
Prices include shipping ConUS
The CS monitor can be used on 96+ OBDII gas and diesel
The Turbo Timer is for diesels only.
Not responsible for improper application but will help determine if these will work for your vehicle.
Below are the descriptions from the manufacture.
Enhance your complete driving experience with Edge Insight CS monitors! The Insight CS is an easy-to-install stand alone multi-gauge display. With what would otherwise cost hundreds of dollars and take hours to install, the Insight CS monitors will provide you the most advanced technology ever in engine monitoring. The days of using chunky analog gauges are over!
Additional features and benefits include:
* Full-color, high-resolution, 2.4 in., button-controlled screen
* Compatible with any OBDII-enabled vehicle 1996 and newer
* Displays available SAE data from your vehicle's computer
* Data parameters (PIDs) on CS products will vary by vehicle year, make, and model
* View parameters in numeric or analog style gauge display
* Digital gauge display/scan tool (does not reprogram/tune the vehicle or add power)
* Internet updateable (cable included)
* Displays and clears diagnostic trouble codes
* Displays alerts and records such as RPM, MPH and EGT
* Includes light sensitivity meter to dim screen as ambient light decreases
* Includes universal suction cup mount
* Compatible with optional EGT pyrometer for engine protection
* Can be used in conjunction with Edge or other performance products to read vital engine data
* Compatible with Edge custom dash pods (sold separately)
Edge Products 98604 - Edge Products Evolution CS and CTS Programmers Details
Accessories
The EAS Universal Turbo Timer is designed for all diesel engines besides the 2006-2011 Dodge Cummins. The 2006-2011 Dodge Cummins EAS Turbo timer part # is 98612. The 2006-2011 Dodge Cummins uses different connectors for installation.
A turbo timer is a device designed to keep an engine running for a pre-specified period of time or a until a specific temperature is reached in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. This also allows the lubricating oil from the engine to circulate properly so the turbine won't burn the lubricating oil that would otherwise be trapped within the charger with the turbine rotating at high speed.
The Edge Accessory System (EAS) was created with future expandability in mind. The architecture of the EAS allows users to connect multiple accessories, daisy-chain style, to the CS and CTS platform. The ability to daisy-chain multiple accessories using the EAS allows users to monitor and display dozens of parameters on a single device.
* Turbo timers are only available to work with the CS and CTS product lines. In order to use the turbo timer you must have an EAS Starter kit (part # 98602). EAS Starter kits come with all Juice w/ Attitude CS and CTS products and the EAS Starter Kit w/ Expandable EGT (part # 98603).
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-11-2015, 11:14 PM   #2
UKNOWME
UKNOWME's Avatar
Re: Edge Insight CS Monitor 83730 and Edge Turbo Timer 98604
Pic of CS unit
1964 Chevy c10
Old 01-22-2015, 12:27 AM   #3
UKNOWME
UKNOWME's Avatar
Both are sold
1964 Chevy c10
