Old 01-12-2015, 11:24 AM   #1
thurmatt
67 c10 first build
thurmatt is offline   Reply With Quote
Old 01-12-2015, 11:26 AM   #2
thurmatt
Re: 67 c10 first build
Old 01-12-2015, 11:27 AM   #3
thurmatt
Old 01-12-2015, 11:36 AM   #4
thurmatt
the story for this build.
my grandpa is a long time hot rod builder and has a lot of knowledge. i love to go help him on his projects. but i wanted to build one of my own. so i picked up the 67 and the guy had tried to put it on an oldsmobile frame but i didnt like that idea. so i started looking for a frame. found a 71 long wheel base frame and went a picked it up with the plans on cutting it down to a swb. then i found a 69 short wheel base frame so i went and go it and ended up swapint the 5 lug from the 71 to the swb frame. i wanted to lower the truck and bag it but this is somthing that my grandpa doesnt know andything about and im still learning mostly from this forum. so i started looking how to get it low for little cost i came across drew715s build where he z'ed the frame and my prandpa builds z'ed frames all the time for his hotrods. so i did all the reserch and this is what i came up with. 3 in in the front and 5.5 in in the back. this is as far as i am at this point. i owe alot of thanks to people of this forum yall can do some amazing stuff and am gald that yall are willing to share it because i would not be able to do some of this stuff without the info on this forum. thanks Matt
Old 01-13-2015, 02:11 AM   #5
swamp rat
swamp rat's Avatar
Its been a long time since i have seen that approach for lowering, it may have been on a TV show some time back, anyway you sparked my interest so i'm subscribed.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-13-2015, 02:33 AM   #6
gdavis
gdavis's Avatar
Never seen anyone lower their truck this way, but I guess it will work. I have to keep my eye on this build. George
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 01-13-2015, 01:36 PM   #7
low&slow
I'm defiantly in on this
low&slow is offline   Reply With Quote
Old 01-14-2015, 09:41 AM   #8
thurmatt
waiting on ubolts for the trailing arms so i started with the floor and rockers on the cab i got the new floor welded in last night just forgot to take a pic.
Old 01-15-2015, 01:31 AM   #9
gdavis
gdavis's Avatar
looks good so far George
Check out Patches
Old 01-15-2015, 03:22 PM   #10
boynton
boynton's Avatar
What did you do to get the core support to line up with the cab/fenders? Following for an interesting build!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 01-15-2015, 06:07 PM   #11
low&slow
He z'd the front of the frame right behind the core support mounts allowing the core support to drop. You can see it in post #3 second picture. Hope this helps.
Old 01-15-2015, 06:30 PM   #12
thurmatt
Yep that's correct dropped the core 3 in same as front cab mounts
Old 01-15-2015, 07:20 PM   #13
low&slow
Maybe I'm a bit confused, but you said you're not using bags, so what are you going to use for suspension? Is it just basically a body drop w/out suspension drop?
Old 01-15-2015, 07:29 PM   #14
boynton
boynton's Avatar
Ah yes I missed that. Makes complete sense now.
1970 SWB Step-Side
Old 01-15-2015, 07:50 PM   #15
thurmatt
I'm using bags just got them in
Old 01-20-2015, 11:12 AM   #16
thurmatt
got the innner and outer rocker cab corner on the passanger side complete. and most of the driver side complete couple of afternoons this week and it should be done. ready to go get my bed and get it cut down. after doing some looking on the forum i found that to make a long bed a short be u need cut 12 in out from the front of the wheel wel and 8 in out of the back. is this correct. thanks matt
Old 01-20-2015, 11:25 AM   #17
Justin@EntropyRad
Justin@EntropyRad's Avatar
how was the fit on the rockers?
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 01-20-2015, 11:52 AM   #18
thurmatt
the driver side went well the passanger side needed some help
Old 03-09-2015, 09:12 AM   #19
thurmatt
its been a while but i have been busy on the truck and at work. Name:  20150225_093053_resized_1.jpg
cut my long bed down to a short bed.
Old 03-09-2015, 09:14 AM   #20
thurmatt
got my air bags and C notch installed and operating of the house compressor
Old 03-09-2015, 09:16 AM   #21
thurmatt
put the truck back together to see what it looks like. loks pretty good but going to need drop spindles.
Old 03-12-2015, 07:34 PM   #22
thurmatt
done some shaving on the fire wall and bed today.
Old 03-12-2015, 07:34 PM   #23
thurmatt
one more
Old 05-01-2015, 04:12 PM   #24
thurmatt
got some mor work done
also had a spare step bed laying around so i mad the bench for my grandpa
Old 05-01-2015, 11:33 PM   #25
cooperhw
cooperhw's Avatar
Coming along nicely. Love the bench too. I am sure your Grandpa will as well.
I will be following along for the ride.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
