01-13-2015, 09:15 AM | #1 |
Lokar cable linkage
Im having a heck of a time installing my cable linkage from my column to my 700r4 from lokar. The collar that clamps on the column will not position correctly due to not having space between the firewall and fender well. Has anybody had any success installing this kit?
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer Last edited by mgkgmc; 01-14-2015 at 09:10 PM. |
01-13-2015, 02:27 PM | #2 |
Msgt USAF Ret
Re: Lokar cable linkage
I haven't used it but here is a picture of it installed outside the truck. I can see how the column mount bracket would interfere with the fender well. In the text with the picture it says that the column mount bracket will rotate around towards the engine . It also looks like the shifter arm on the column is pointing to the left and mine points to the right to the engine. Can you rotate the column bracket toward the engine? It looks like there might not be enough room to me.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-13-2015, 03:50 PM | #3 |
Ill get pictures later of what im dealing with but thats my next thing im going to try but I heard when its on the other side you'll have trouble lining up the indicators for the gears. But I could be wrong about that.
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
