Old 01-19-2015, 07:18 PM   #1
michael bustamante
michael bustamante's Avatar
seat belt cleaning and dyeing
ok so i pulled the belts out of my 67 and they are in good shape but crusty and stiff. so what s the best way to clean these and have any of you had luck redyeing the webbing and plastic?
1967custom
michael bustamante is offline   Reply With Quote
Old 01-19-2015, 07:35 PM   #2
Sklptrljay
Sklptrljay's Avatar
Re: seat belt cleaning and dyeing
I think Led Zep has a thread on this. I washed mine in the washer, and then boiled in the color with RIT dye.
I used spray paint for the buckles.
I thought they turned out pretty good.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 01-19-2015, 09:13 PM   #3
1968aj
RIT dye. made mine look good. got a small plastic tub and threw them in.
1968aj is offline   Reply With Quote
Old 01-20-2015, 12:39 AM   #4
michael bustamante
Boiled the dye in?. Do you guys have trouble with bleeding on you clothes when wearing the belts? Ill have to find the thread
1967custom
Old 01-20-2015, 04:35 AM   #5
HeavyD
HeavyD's Avatar
For cleaning a bucket of hot water/ strong simple green mix and a scrub brush should help with the crud issue
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 01-20-2015, 12:27 PM   #6
michael bustamante
simple green, good idea and i have a half a bottle left. thank you. anyone got pics of redyed seatbelts? dyieing a different color i mean? i dont think my red belts will match my new grey and silver interior anymore
1967custom
Old 02-05-2015, 06:48 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Very timely thread for me. I took my parchment seat belts apart yesterday because they weren't retracting and now i know how to clean them I need to find the parts to fix them, and I haven't found a vendor that sells a repair kit for seat belts.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-05-2015, 10:14 PM   #8
1972BlueC20
1972BlueC20's Avatar
I used tuffstuff and a carpet brush to clean some oem 72 seat belts I got off ebay today. Cleaned em up about 70 % but they need more cleaning and some brightening up. I guess I can try simple green or some oxyclean.
If you put them in the washer how do you take the plastic housing with the button off?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 02-06-2015, 12:04 AM   #9
suville
suville's Avatar
Good topic! I like usin as much OEM stuff as possible, just me
suville is offline   Reply With Quote
Old 02-06-2015, 02:54 AM   #10
BruthaMan
US Army Veteran
BruthaMan's Avatar
Rit also makes a stain remover that works pretty good.
Amazon.com: Rit Dye Liquid 8 Ounces-Super Stain... Amazon.com: Rit Dye Liquid 8 Ounces-Super Stain...
BruthaMan is offline   Reply With Quote
Old 02-06-2015, 03:18 AM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Have you considered new belts? At nearly 50 years old, those might not hold up very well if you're unlucky enough to have an accident. Seems like there's one or more threads here about replacement belts including some that are made to look the same as the originals.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 02-06-2015, 05:29 PM   #12
WayOutWest
I bought a center belt (dark olive green) from ebay. Washed all my belts in a 5 gallon bucket with watered down laundry detergent. Let them dry on a hanger. Once dry, I boiled water, a coupe liberal palm fulls of deionized salt and the only dark olive green dye I could find (antique, also ebay). Used a large Spaghetti pot about 3/4 full of solution. Let it boil for a couple minutes, then lowered the temp by about 1/2. Put the belts with good color in for about 4 mins. and the faded belt for 12-15 mins. Keep the belts stirring, don't let them sit on bottom. Rinse with cold water when taken out. Repeated drying process.
They look great, but I didn't think of their age or integrity. HMMM?
WayOutWest is offline   Reply With Quote
Old 02-06-2015, 05:38 PM   #13
michael bustamante
has the dye held up for any of you guys that have dyed them or did you end up with a green ( or other) lashing across your lap from the dye?
1967custom
Old 02-06-2015, 07:50 PM   #14
leddzepp
Moderator
leddzepp's Avatar
I dyed mine back to black years ago, still look great. I wouldn't worry about the integrity of them, lap belts are worthless to begin with. If you are really concerned about safety then you should install 3-point belts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 02-06-2015, 11:36 PM   #15
zibs71
zibs71's Avatar
Anyone have pix of them after u dyed then . I put mine in dish soap overnite with hot water . Didn't turn out to bad, but then i soaked them in Oxi Clean and they look like hell !!!!! So i thought I'd try that Rit dye but was to scared....lol I'll wait till i see a before and after pix before i do this. Great Topic!!
Zibs71
zibs71 is offline   Reply With Quote
