Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-29-2015, 08:32 AM   #1
90\87Formula
90\87Formula's Avatar
gas gauge sticking on Full
I just bought a 2002 Blazer Extreme.
When the key/ignition is turned on the gas gauge goes to Full and stays. I know the tank is nearly empty because I have driven close to 200 miles on the last tank fill.
When the key/ignition is turned off the gas gauge goes back down to Empty.
Any suggestions of what to look for?
I know enough about electrical to make me dangerous.
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 01-29-2015, 02:28 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: gas gauge sticking on Full
I'll bet your check engine light is on also with I believe a code P0463
Fuel level sender is bad. The tiny little fingers that wipe across the resistor are broken. Dorman makes a sender but since it has metal and plastic I ouldnt trust it. Go AC Delco
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 01-29-2015, 03:13 PM   #3
90\87Formula
Yep, Check engine light comes on.
Don't have anything to check codes with.
Robert
Member 1532
