02-01-2015, 12:07 PM | #1 |
new alternator
assume you have no wiring harness currently. A small block 350. drivers side alternator with a long water pump. 10si style brackets.
not going to have any fancy additional power requirements. basic radio, heater, Factory AC, HID headlights. What alternator would you get? Brand? Amps? |
02-01-2015, 02:15 PM | #2 |
Re: new alternator
12si 94 amp should be more than sufficient. Rock Auto has ACDelco rebuilt ones for about $80. Wire it up for 3 wire operation. See this from MAD.
http://www.madelectrical.com/electri...evymain1.shtml
02-02-2015, 03:30 AM | #3 |
Re: new alternator
You could go as low as 74 amp and it should be fine.
Oh, A driver side alternator on our trucks equates to a short water pump not a long one.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-02-2015, 03:41 AM | #4 | |
Re: new alternator
