02-02-2015, 04:56 PM | #1 |
Front upper ball joint fitment
I've got a 72 c20 that I'm converting to c10. I bought an entire front crossmember from a 69 or 70 c10 and a set of spindles from a 71 so I can keep the disc brakes.
From what I have read on here I should just be able to install ball joints for a 72 c10 and then install the spindles but the 72 ball joints (upper) are .1" larger in diameter than the hole in the a-arm. The ball joints I have are designed so the rubber boot is actually in the hole of a-arm. I believe that is the extra .1" of diameter. The lower ball joints are pressed in so the rubber boot is put on after installation and snaps onto a groove around the ball joint. The uppers aren't made the same way. These are Moog parts and the numbers seem to match what everyone else is using so I do not think its the parts. Has anyone had an issue like this? I do not just want to open the hole because I would be getting very close to the mounting holes.
Only Two...... Only two have laid down their lives for you, Jesus Christ and the American GI. 2007 Chevy 2500HD 4x4 Duramax 1970 Chevy K20 (SOLD) 1972 Chevy C15 (1/2 C10, 1/2 c20) 1970 Chevy C10 (parting out) |
02-02-2015, 07:10 PM | #2 |
Re: Front upper ball joint fitment
Ok, never mind. I figured it out. How about putting the rubber boot UNDER the a-arm.
Good think I still have my dunce hat.
