Old 02-02-2015, 08:22 PM   #1
69SCSS
69SCSS's Avatar
Ram Horns and dual 2.5" exhaust
Hey guys, I'm tired of listening to my cheap headers make what sounds like an exhaust leak noise under my truck, and it's driving me NUTS!!! I have a full 2.5" exhaust on my truck, and wondering if a set of stock ramhorns would be too small. The collectors are 2.5", right? Just concerned that the 2.5" pipes are too much behind the manifolds. I know there's a big debate about backpressure levels (negative or positive), I'm more concerned about sound and efficiency.
I'm guessing it'll work just fine. Any thoughts appreciated.
Thanks!
Al
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 02-02-2015, 08:26 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Ram Horns and dual 2.5" exhaust
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-02-2015, 09:04 PM   #3
Mike C
Mike C's Avatar
Bunch of threads on the 2 1/2" manifolds. I went from headers and 2 1/4" exhaust to manifolds and 2 1/2" exhaust. Running Dynomax Hemi Turbo mufflers (20" case). One of the best mods ever on my Jimmy.
As soon as I get a chance to put some pipe in the crossmember on my shortbed for exhaust clearance I'm going 'Vette rams horns on it with some Magnaflow mufflers I got off a parts truck I had.
You will have no issues ditching the headers IMO. I think I actually gained some low speed torque with my swap. And I got rid of the hassles of headers. No complaints.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-02-2015, 09:09 PM   #4
69SCSS
69SCSS's Avatar
Unfortunately the search function is still down, so finding those threads is tough right now.
Good to hear someone else has done it and it works out. Kinda figured, but wanted to get some opinions first.
My 68 SWB
Al Silveira Music
Old 02-02-2015, 09:29 PM   #5
Mike C
Mike C's Avatar
I think you'll be happy. I know I was enough where I'm going to do it again!
If you type "corvette rams horns" in the bar for what passes for a search box and radio button the 67-72chevytrucks.com button it comes up with loads of threads from the site.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-02-2015, 10:46 PM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I only run 2.5 straight dump ram horns on my trucks - 4x4. Over the years I have picked up sets that were designed for Corvettes, modify them a little. The only issue is ensuring that you use the correct ex. manifold gasket or they will start leaking after a few thousand miles. If you go that route, measure the port size of the heads and port size of the manifolds, then look on Summit for the best match.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 02-02-2015, 11:10 PM   #7
The truck manifolds aren't 2.5", but no problem going with 2.5" exhaust
Old 02-02-2015, 11:17 PM   #8
69SCSS
69SCSS's Avatar
Are they 2.25" or 2.75"? The big block ones were 2.5" if I remember right.
My 68 SWB
Al Silveira Music
Old 02-02-2015, 11:47 PM   #9
SierraMtns
SierraMtns's Avatar
I believe the stock OEM truck ones are 1.9".
SierraMtns is offline   Reply With Quote
Old 02-03-2015, 12:11 AM   #10
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Here is an example:
http://www.ebay.com/itm/64-65-Corvet...8b66eb&vxp=mtr
I trim off the alternator mounting flange. After that - in appearance they look identical to stock 67-72 OE straight dump truck manifolds. Again with the exception of the diameter of the exhaust pipe mounting flange.
I run 2.5 pipes from the collectors to the tips - no issues.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 02-03-2015, 12:22 AM   #11
leftybass209
leftybass209's Avatar
The corvette 2.5's will work regardless of engine position you just need a competent exhaust guy to route the pipes. The style muffler you choose will effect the back pressure, but I think just about any mild+ Chevrolet v8 can handle 2.5 exhaust with no issues.
leftybass209 is offline   Reply With Quote
