Old 02-04-2015, 12:10 AM   #1
Sprinter7x
1972-4x4 light
Recently bought a GMC K1500.I would like to have some kind of light showing when in 4x4,has anyone rigged one up?
Sprinter7x is offline   Reply With Quote
Old 02-04-2015, 08:44 PM   #2
franken
Re: 1972-4x4 light
Late model NP205s had a switch in the outer detent spring/ball setup rather than just a plug, spring and ball. You may be able to still find one for an 86+ 1-ton, maybe others.
Google says GM P/N 15594176
https://www.google.com/?gws_rd=ssl#q...+detent+switch
franken is offline   Reply With Quote
Old 02-04-2015, 09:33 PM   #3
Sprinter7x
Re: 1972-4x4 light
Thank's franken.
Old 02-05-2015, 10:03 AM   #4
Re: 1972-4x4 light
I have a light in my head
Old 02-05-2015, 06:30 PM   #5
Mike C
Mike C's Avatar
Re: 1972-4x4 light
205's are usually loud enough when in 4x4 that you have no problem knowing... And on mine, the bumpsteer will clue you in pretty quick!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-05-2015, 08:31 PM   #6
slotard
Re: 1972-4x4 light
Why do you get more bump steer in 4WD?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-05-2015, 11:43 PM   #7
mrolds88
Re: 1972-4x4 light
Just go around the corner in 4x, you'll understand.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 02-06-2015, 08:08 AM   #8
Bigdav160
Bigdav160's Avatar
Re: 1972-4x4 light
Because, in these 4x4's, the drag link moves in an arc as the suspension goes up and down. Since it's connected to the steering box it moves the steering wheel back and forth
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-06-2015, 12:12 PM   #9
71K20chevy
71K20chevy's Avatar
Re: 1972-4x4 light
Mine makes no noise at all when in 4x4. You usually find out when trying to turn a corner
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 02-06-2015, 01:53 PM   #10
BLT gmc
Re: 1972-4x4 light
Search for this in 67-72 Tech Tips "67-72 New use for the empty slot in a tach cluster"
An interesting lighting option to your idea. Bruce
BLT gmc is offline   Reply With Quote
Old 02-06-2015, 03:19 PM   #11
Bigdav160
Bigdav160's Avatar
Re: 1972-4x4 light
Too bad the only switch I can find is $100. Maybe I should look at a Dodge application. Did they have a light?
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 02-06-2015, 04:22 PM   #12
slotard
Re: 1972-4x4 light
Mike C claims that you can tell by the bump steer whether or not it's in 4WD. I understand why there's bump steer, just not why being in 4WD would change it.
1973 C20, 350/350
Old 02-06-2015, 05:54 PM   #13
Bigdav160
Bigdav160's Avatar
Re: 1972-4x4 light
Sorry I mis understood
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 02-07-2015, 09:36 AM   #14
Re: 1972-4x4 light
I guess he's saying you can't help but notice when 4wd is engaged by the many ways you feel the difference of the front wheels being engaged. I guess the most likely time you'll be in 4wd when you didn't intend to is when it was left in the last time you drove. It doesn't take long to notice, if roads are clear. I routinely put it back in 2HI before I get out. I often need 4wd just to back up my driveway. Even in my '92 with a graphic display on the console I would pull out and wonder why the truck felt funny, then look down at graphic and DOH! Never got far w/o realizing.
Old 02-07-2015, 08:43 PM   #15
franken
Re: 1972-4x4 light
Heh, I didn't check the switch price. $100 would hurt.
A cheaper route might be a weatherproof limit switch on the shift linkage.
Old 02-09-2015, 05:34 PM   #16
Orange Crate
Orange Crate's Avatar
Re: 1972-4x4 light
Search is completely busted because nobody tipped their server.... (Migrating to a new server)
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...
Orange Crate is offline   Reply With Quote
Old 02-09-2015, 09:54 PM   #17
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 1972-4x4 light
While you cant search a specific subforum, the google box at the top pointed me right to it: http://67-72chevytrucks.com/vboard/s...d.php?t=449590
I like it.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 02-10-2015, 11:01 AM   #18
joeydurango
joeydurango's Avatar
Re: 1972-4x4 light
Yeah, it's pretty difficult to drive for any length of time in 4WD without knowing it. Everything feels different.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
