What have I got here?
So I bought what I thought was a 68 long bed for either a quick flip or a part out. It definitely has a 68 front clip on it but the cab has a foot emergency brake and the front suspension is different than a 68 should have had. The frame is a rear leaf spring vs trailing arms.
What I don't know is was the truck put on a newer frame or was the front suspension upgraded on a 67 to 72 frame. The lower control arms have pretty deep spring pockets that appear to be unmodified. So back to my question, is there some ways I can identify what year the frame, cab, front suspension and bed is? I know pictures will help but I don't have any yet because I just got it home late last night. I will post a few in a day or so. Please give me some areas to look at or clues to how to determine model years. Thanks for any help!
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
Re: What have I got here?
Rubber bushings or screw in on the control arms? Disc brakes or drum brakes? 2 1/4" wide rear leafs or 2 1/2"? 127" wheel base? Stock cab mounts on the frame or fabricated? Bolt holes in ends of cylinder head? Short pump or long pump? Alternator on driver or passenger side?
Please get some pics. This list could go on and on and on...
Check the VIN on the top of the frame, drivers side, close to where the PS pump is or should be if equipped. Sometimes you have to clean the top of the frame to see it. Does it match the VIN on the door jamb? Sounds like it may have a swapped out front clip or cab.
#4 | |
![]() Join Date: Nov 2001
The leaf spring is entirely possible as some 67-72 Chevy/GMC 2wd and all 4x4's had leaf spring from the factory.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
Cab: Rearview mirror on windshield or on cab ceiling?
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
Since I am on an iPad i can only post one pic at a time. Here is what is on the lower control arm shaft.
![]() Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS Last edited by HSRACER; 02-04-2015 at 11:41 AM. |
Control arms
More
Backside
Cab mounts look factory
Another
Cab
#13 |
Outside cab
#14 |
Definitely a 2 1/4 leaf spring.
#15 |
![]() Join Date: Sep 2007
looks like a 69-72 with a 68 front clip on it does the tailgate say Chevrolet or GMC?
1967custom |
#16 |
A 34-2714 is a "stock replacement-reproduction" LH Lower control arm from LMC
#17 |
#18 |
So,, what else you got???
![]() Join Date: May 2010
71 cab. Disc brakes started in 71 as well as 5 lug wheels.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
#19 |
yup to me it looks like a 71 body and 68 clip
1967custom |
#20 |
1972 K20
![]() Join Date: Apr 2008
Another thing to look for. 71 and 72 cabs have a different VIN tag and a vent above the tag.
#21 |
B chevrolet
#22 |
The vin is below the vent on the drivers door. It appears that the vin plate may have been moved. I will have to look closer
#23 |
So is there a code on the vin tag that identifies the year built like on the new cars? With 12 digits maybe not?
#24 |
Here is the deal the way I understand it on the springs[rear] The coils were standard for the Chevrolet's but an option for the GMC's and the leaf were standard on the GMC's and an option for the Chevrolet's. There now is that as clear as mud for every one? Your welcome. The room will stop spinning soon I promise. Jim
#25 | |
![]() Join Date: Sep 2011
the 5th digit is the year. Sounds like a Frankenstein parts trk to me.............
1967 C10 SWB Owner - Rustbelt Restorations |
