Water in tranny???
I have a '68 with a 250, 3 on the tree. I pulled the side plug to check the gear oil in tranny, & it was bad looking. So I decided to pull the bottom plug to drain it out & refill with fresh oil. When I pulled the plug, a good 8-10 oz. of clean water poured out, then the nasty brown gear oil came. Is this normal? ....truck has been sitting for over 20 years...
'68 Chevy C10 '06 Saleen Mustang #725 (Convertible) ![]() '04 Infiniti G35 '01 Infiniti QX4 |
![]() Join Date: Nov 2001
Re: Water in tranny???
Entirely possible. Years of condensation and who knows, maybe it was driven through a crystal clear creek the day before it was parked ???
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 02-05-2015 at 12:53 PM. |
could only be two things. either the tranny was under water or condinsasion can,t spell that one. some of the trannys did not have a breather on top. might be alittle rust in there. If ya get a chance to look inside might be a good idea.
#4 | |
I outta be a under cover FBI type guy.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
might be a good idea to run it acouple minutes with some tranny fluid or some diesel and then drain it and fill
#8 | |
He would drain out the old oil and fill em up with an ATF and run em about 20 miles. Drain all that out and be good to go.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
