Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-05-2015, 08:25 PM   #1
Andy4639
Old member
Andy4639's Avatar
Wink Electric seats/heated
Ok I started on the truck last weekend while I was off and got the new carpet in along with the gear shifter. I had to build the enclosure around the gear shifter also since the old one wasn't level.
I started today on drivers side so I hope to drive it this weekend hopefully. The new fuse panel did fine after hooking up the electric/heated seats.
I got the sub box in and corner drivers side speaker enclosure installed. I need to decide if I want to paint them are cover them with carpet. I also have to fill in behind them with insulation. I have the drivers seat in and wired also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-06-2015, 04:38 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Electric seats/heated
cool I just got some too,what kind are those?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-06-2015, 07:21 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Electric seats/heated
Are you speaking of the seat's? They are 1999 Tahoe front seats. All the controls are on the door side of each seat. Both seats work great now. The heater in the drivers side I never got to working so I bought aftermarket heating pads for both seats backs and bottoms the factory was just bottoms.
I took and cut the opening just enough to insert the switch in the factory spot and I wired everything to the factory wiring harness. I even wired the heater through the seat belts so if the person forgets to turn off the heater when they unbuckle it shuts off.
I had them in for about 2 months but I found a center console to install and it hit the S-10 shifter so I had to pull everything back out to get the new carpet in after realizing the shifter left a great big hole in the carpet!
Old 02-10-2015, 05:39 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
sounds/looks like a nice upgrade,
and keeping it all GM is nice,I got a set of dodge ones free to play with
John
Old 02-10-2015, 09:20 PM   #5
Andy4639
Old member
Andy4639's Avatar
Thanks I try!
Old 02-10-2015, 11:18 PM   #6
Jim53066
Jim53066's Avatar
where did you find the new covers for the gm seats?
I have a 99 that needs new covers, and those look good.
Jim
Jim53066 is offline   Reply With Quote
Old 02-11-2015, 03:25 PM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Electric seats/heated
Jim
Thanks I was really pleased with them.
Can't believe they aren't leather covers. I bought them off this site.
http://www.autoanything.com/seat-cov...A4353A0A0.aspx
