Old 02-10-2015, 01:46 PM   #1
DaHos
DaHos's Avatar
Question found a doner... what parts?
I have found a 6.0 4l80 combo in a 2001 2wd 2500.
Other than the obvious items, what else should I have pulled. I wanted the entire truck but that is not possible due to the seller.
Motor
Manifolds
Ecu
Ft drive accessories
Harness
Thx!
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 02-10-2015, 02:58 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: found a doner... what parts?
The transmission usually helps
Otherwise its accessory stuff thats optional. Some folks might take stuff like power steering hoses, A/c lines, fuse boxes, engine covers etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-10-2015, 09:26 PM   #3
kitsbeach
kitsbeach's Avatar
How about fuel pump (and tank too?) and regulator and someone else said he even used the radiator out of a 2500hd. So fans and the whole bit.
I'd try to use use everything I could so I don't have to take my wallet out for all the little parts.
Depends if the vendor will let you grab it all or if you have to pay for everything.
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
kitsbeach is offline   Reply With Quote
Old 02-11-2015, 02:04 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
OE tanks are HUGE and cumbersome IMO. I've never used the OE pumps either, as I've needed more fuel pretty much immediately. The stock pumps can't handle 400hp reliably imo.
The truck regulator is on the fuel rail, so it'll come with the engine already.
Take transmission lines!
