02-11-2015, 11:04 PM | #1 |
Hatch supports
any info on these Rear hatch supports? my 72's Supports needs some TLC
02-12-2015, 12:50 AM | #2 |
Carpe manana
Re: Hatch supports
We all could use a hug from time to time. What's up with the supports - bent? Pics?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
02-14-2015, 02:26 AM | #3 |
Re: Hatch supports
These are the ones, they hold but the internals stick? not sure how they work first set. thanks in advance, Chad.
02-14-2015, 01:22 PM | #4 |
Re: Hatch supports
Mine were in decent shape only didn't work all that well. Took them apart, slides slide out backwards. ( That's clear as mud )...cleaned all surfaces inside and out with fine steel wool (0000)..reassembled with gel lube. They work really well now.
02-18-2015, 11:04 AM | #5 |
Re: Hatch supports
Do you realize your hatch struts are only screwed in with one screw on each end!?!
There should be two screws on each end. Look at your picture, the ends are just flopping around! That's a great way to destroy your nice single wall top in a hurry |
02-18-2015, 06:55 PM | #6 |
Re: Hatch supports
I have some of the original style bolts for the struts in the blazer for sale section I moved it to the top so it should be easy to find.
