02-20-2015, 06:26 PM | #1 |
1970 Blazer seat interchange question
What options for seats do I have for other year Blazer or Sub........front buckets and rear seat?
Thanks,
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
02-23-2015, 07:32 AM | #2 |
Re: 1970 Blazer seat interchange question
Anyone got any ideas? Looking for options
Thanks Stuart
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC Last edited by scf100; 02-23-2015 at 07:39 AM. |
02-23-2015, 10:13 PM | #3 |
I'm trying....
69-72 Blazers came with two bucket seat options, the base bucket often referred to as the utility bucket...and the sport bucket. The utility bucket (top pic below) was wider, not tapered, and had a metal back. The sport bucket(bottom pic in top of the line CST trim) was generally the mid-level and top line seat option. The sport bucket frames were unchanged through Gen 1, but the foam and upholstery were different between 69-70 and 71-72. The rear seat only varied in upholstery depending on trim level.
The truck sport buckets are the same during this period except for passenger mounting brackets and seat back covering. You can put any seats you want in your truck. Common custom choices are later model Tahoe seats front and rear because of integral shoulder belts which are there even when the top is not. There are several threads I'm sure detailing this conversion. There also plenty of people running aftermarket or racing style buckets front and rear. Later 70's Blazer seats are very similar and will go in will little mod or fuss...It all depends on what you want.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
